Wheel Fitment Guide
#511
^I think you mean the former makes sense. I am certain you have the 8.5/9.5 combo. This is what I have seen on alot of s2000's. Does your rear stick out past the fender or sit really flush?
#513
Just recently picked up a set of 17x7.5 17x8.5 Volks in a +40 offset all around. Based on the chart I am assumming that a 215/45/17 tire in the front will be pushing it with 245/45/17 rears. The tires I am looking into are Falken Azenis. Has anyone had any issues with a setup similar to the ones I have on an AP2? Thanks!
#514
I'm thinking about picking up a set of Volk LE37's, but the tires that come with them are 225/40/18 and 225/45/18...
the wheels are 18x7.5" +48 in front and 18x8.5" +50 in the rear.
I think the front tire size is good, but would a 255/40/18 or 255/35/18 be better for the rears?
#515
Yes, a 255 would seem to work better there. Not sure about the offset though, I'm not at home right now to confirm. I think it should be 35, but you should double check.
#519
Look at what I wrote above.
Anything wider than 205 on the front is likely to rub. 40 is a very low offset for a S2000. You can roll or pull the fenders to get more clearance, but personally, I would find a wheel with a higher offset. The ones you have chosen for the rear are fine. You have a 62 offset which meets the requirement of a 275 tire on the rear, so a 255 would work too.
Cheers,
Ken
Cheers,
Ken
#520
just bout some kumhos but i think i made a mistake i bought rota torque 17in with +45 front and +48 rear and i bought tires 225/45/17 front and 245/40/17 in the rear will these fit???
