Wheel fitment HELP!
Wheel fitment HELP!
im lowered on skunk2 spring and stock struts, i have 17x9 all around rpf1's. i want to run the smallest tires possible without and tire stretching. and less fender roll as possible and also no pull at all or do i have to pull the front?
I am assuming +45 offset, 225/45 front and 255/40 rear. I would bend the front fender liner tabs up and do a standard roll/bumper tab relocation in the rear but at least you don't have to pull anything. You could also do 215/45, 245/40 for more clearance but you are getting into a decent stretch on the front.
Just roll them, Im on 245's on 17x9 +42 and just camber adjusted and i clear fine
i have 17x9 +45 and 225/45 on the front and it does rub but i think with a little more camber it will be fine. my rears are rolled and the tab relocated. it was like $75 or so for the rear to be rolled and tab done.
