wheel fitment questions
I'm not looking for that hella undriveable look.
I want slammed/agressive/clean look with at least 245s so around -1 camber in rears to fit, same as fronts
Right Now I have 17x9 +45 rpf1s all around front / rear
I have +10mm wide seibon fenders in front and I rub a bit at full lock due to my car being slammed. I can shave the sides of it down and probably gain about a 5mm - 10mms of clearance room.
Rears are tucking and can use alot lower offset
I was thinking 17x9 +30 all around, does anyone have any insight on how it will fit or any other suggestions or advice.
I was also thinking on going 18x9 +41 varrstoens since I can get them for half off retail.
Former Sponsor
You have too many variables to say for sure. Every tire is slightly different in width and height. You would just have too look and see how much more room you have before they hit. The 17X9 Et 30 would need about 2/3" more room that what you have now. The 18X9 would only need about 1/6"" so it would be almost the same.
