Originally Posted by steve695
(Post 20772745)
Ill probabably go black, has a more serious look to it.
Car is mainly used on streets but I want to start taking it to the track next year.
Originally Posted by prj3ctm4yh3m
(Post 20773491)
Silver will be more durable than a flat black. Keep that in mind if you're having Tom & Jerry spoon on track tires every other weekend.
(Post 20773491)
Originally Posted by steve695' timestamp='1310618033' post='20777778
[quote name='prj3ctm4yh3m' timestamp='1310572126' post='20774882']
[quote name='steve695' timestamp='1310535141' post='20773678']
(Post 20773491)
[/quote] Oh true, didn't really think of that. I guess I'll have to be extra careful. [/quote] |
(Post 20792706)
Will I rub on 17x9+60 with 255 tires all around with my car lowered to about a finger gap?
Can I achieve the required camber with the standard camber kit? I don't want to have to buy an aftermarket one. My fenders are already rolled. (I don't know if this makes any difference with a +60 offset) Will this setup improve the cars handling? I'm more concerned about handling than I am about looks. And finally, if rubbing is going to be an issue, what can I do to resolve it?
Originally Posted by clarkster009
(Post 20793254)
With this offset there is very little chance of rubbing, especially if your fenders are already rolled. Most people with the +63 have had rubbing on the inside with the steering at full lock. The extra 3mm might be enough to avoid this.
There are numerous people on the racing forum that strongly feel nonstaggered is the way to go. They usually balance things out with a stiffer front sway bar since it will be easir to get the back end to comme out.
(Post 20795021)
Yeah, I'm definitely going to run this set up.
It doesn't look like it's going to be a huge issue. I just get overly worried when I'm buying something from overseas, that it may not work when it arrives. Yeah, I will get a front sway bar, they go for good prices on ebay. If I feel oversteer is an issue, I may install a rear wing. However, I don't really like the look of wings on s2ks. The only ones I really like are the OEM lip spoilers, I doubt that these help with downforce though.
Originally Posted by hatrickstu
(Post 20812178)
Anyone stagger the 9s yet? Like a 60 up front and the 48 out back?
Originally Posted by Ddub-S2K
(Post 20818660)
These fit perfect with no rubbing and no fender modification with 255s all around.
(Post 20818888)
^Nice to both. No rubbing on the +48 even on the track? Is there very much caliper clearance up front?
Any idea what wheels, size, and offset these are? http://www.waypast210.com/Other/NASA..._8Vd4cbB-XL-LB
(Post 20818926)
Any info on fitting 48s on all 4 would be appreciated. Curious as to what has to be done up front
(Post 20819888)
Basically, on the fronts run a 215 (if we are talking Star Specs et al) or 225 tire, run 2+ degrees of negative camber and manually push up/in the fender liner tabs a bit. Should have no problem with that. On the rears, you will want a mild fender roll and a relocation of the tabs. If you dont, make sure youre close to stock ride height with 2.5 degrees of negative camber and 245 tires.
(Post 20820044)
i race the car, it will have 255's on all four. rears im not worried about ive got that under control. those that have seen both the 48 and 60, is there a difference in lip?
(Post 20820044)
255s on the front, Im sure you know already, require pulled fenders to avoid sucking off a fender liner and/or tab.
Originally Posted by hatrickstu' timestamp='1311775293' post='20820088
[quote name='prj3ctm4yh3m' timestamp='1311774643' post='20820055']
(Post 20820044)
255s on the front, Im sure you know already, require pulled fenders to avoid sucking off a fender liner and/or tab. [/quote]
Originally Posted by prj3ctm4yh3m' timestamp='1311775416' post='20820099
[quote name='hatrickstu' timestamp='1311775293' post='20820088']
(Post 20820044)
255s on the front, Im sure you know already, require pulled fenders to avoid sucking off a fender liner and/or tab. [/quote] you're right. I had the 48s in mind and forgot to distinguish the 60s [/quote] |
(Post 20823735)
(Post 20824717)
Just got off the phone with enkei international. There is no aesthetic difference between the 48 and 60. Its all in the backspacing. No change in lip
(Post 20849116)
Originally Posted by deepbluejh
(Post 20850129)
Personally the black just isn't doing it for me. The wheels are so dark you can't see the spokes clearly. It's almost as if the wheel spoke design doesn't matter at that point because you can barely notice it. That's a shame since it's such a nice looking wheel. The silver looks much better, IMO.
I'd love a set of solid white PF01Rs for my Laguna blue. They have one, but it has a machined lip - a look I'm not a big fan of.
(Post 20849116)
(Post 20850129)
I'd love a set of solid white PF01Rs for my Laguna blue. They have one, but it has a machined lip - a look I'm not a big fan of. In real life, they honestly look freakin sweet! My set arrived last week and I got the tyres fitted yesterday and then put them on. They look great on Silverstone. the +60 offset sits perfectly, only a little under flush with the guards. Oh and just incase this info is any help to anyone: I'm running 17x9+60 all aroud with 245 tyres all around and I do not rub, even on full lock. I am stock height at the moment but have coilovers being installed next week and will be going pretty low, I will report back.
(Post 20863419)
Originally Posted by hatrickstu' timestamp='1312655283' post='20853892
Yea I wasn't a huge fan until I saw them in person. Truly a "pictures don't do justice" scenario
(Post 20893747)
Originally Posted by Scotty2H
(Post 20897403)
Well, I read the thread and really like the wheels. I will not do any fender rolling, pulling or tab relocation. I just want a set of wheels to put on the car.
It appears that the 17x9" +60 will fit with 255 all around with no rubbing on a mild drop. Which is what I am going for. I just want to confirm before ordering. Sorry if it seems like a redundant question. Measure twice, cut once right. Thanks for the help!
(Post 20893747)
Silverstone AP2 V1 Shine ASM Front Bumper Koni/GCs 8/9 +48/+60 Sparkle Silver http://i465.photobucket.com/albums/r...h3m/PF01/2.jpg http://i465.photobucket.com/albums/r...h3m/PF01/1.jpg http://i465.photobucket.com/albums/r...h3m/PF01/4.jpg http://i465.photobucket.com/albums/r...0819-00782.jpg |
(Post 20898838)
Originally Posted by hatrickstu' timestamp='1313880182' post='20897941
Just curious why you went with staggered offset?
(Post 20898846)
What size tire are you running in the front?
(Post 20898850)
Originally Posted by RedCelica' timestamp='1313935496' post='20898846
What size tire are you running the the front?
225/45. But in the Sumitomo its seriously oversized. More like a 235.
(Post 20900559)
I just had my coilovers installed and my s is sitting pretty damn low now, on Black PF01's.
It looks great, but I am now getting vibration under acceleration through the car. it wasn't doing this before I lowered it. Anyone else had this problem? How do you fix it?
(Post 20900927)
axle spacers, not wheel spacers. its a 15 minute install and the parts are cheap as hell.
(Post 20900927)
Thanks man!
Originally Posted by hatrickstu' timestamp='1314104269' post='20904556
[quote name='steve695' timestamp='1314048608' post='20902844']
(Post 20900927)
Thanks man! [/quote]
Originally Posted by nmrado
(Post 20905071)
no they just push the axle back out so its at the right angle
Originally Posted by the_KiLLaBEE
(Post 20918573)
Just installed mine last night in black. 17x8 50 in front, and 17x9 60 in back and stock tire sizes. I love them on my Seb silver. Ill try to put pics soon
Originally Posted by 4bangr-604
(Post 20924988)
i really like the new style of these wheels. i want to pick some up, was thinking about non-staggered after reading some other topics and think that the grip would be just crazy with 255 all round. if i went for a staggered set up with 17x8/17x9 what tire set up would be best 225/255 or 235/255? tire would be star specs. but i am seriously considering 17x9 all round with 255's, guess that would need the +60 offset or can you run them with +60(f)/+48(r) with little fender mods?. i use my car as my DD which is the better choice? As for colour choice i was thinking white with machine/lip on my BB not sure about the machine lip but worst case just get them powder coated if its a problem.
(Post 20925219)
there is not point in doing the +48's IMO. the outer face does not change in appearance (as would be the case with the rpf1). you will not have fitment problems unless you are low and have soft suspension with the 17x9's and 255's with the +60.
Originally Posted by //steve\\
(Post 20925396)
^Disagree. There is a look aspect to it. Yes the wheel face looks the same and you get no more lip but the car will look much nicer with the wheels sitting a lot more flush to the fenders. And this size is by no means pushing it as far as fitment goes.
I need to find someone to trade me a set of the 9 +48s for my 9 +45 rpf1s
(Post 20924988)
215/245s with the star specs is pretty flipping big on a 8/9.
(Post 20925396)
I need to find someone to trade me a set of the 9 +48s for my 9 +45 rpf1s |
(Post 20932871)
I have 17x9+60 and it sits nicely.
It isn't "hellaflush" but it does not look sunken in at all. It looks really good in my opinion. Not to mention, I have no rubbing and I'm sitting pretty low. 17x9+60 is practical and looks fine, and you don't need to run as much camber. I'm only running 1.5 up back and 1 up front.
(Post 20935938)
^ are you running 17x9 on all corners? have any shots from behind. cause i want to see a bit of rubber sticking out for that aggressive look . im running on stock wheels/tires lowered to a finger gab with a spring rate of 13 all round. think there will be any issues rubbing with a +60 17x9 and no roll in the rear? i would probably get the 17x8 up front not sure on offset
(Post 20935938)
I will try and get some behind shots later
(Post 20937268)
Originally Posted by hatrickstu' timestamp='1314913122' post='20936015
i posted pics, check them out
man you car is clean. love the spoon top, i always wanted one. your stance does lookhttps://www.s2ki.com/s2000/public/st...ault/photo.gif
(Post 20935938)
I will try and get some behind shots later thanks behind shot would really help. but i guess i could just run a 10mm spacer or so if the stance isn't up to my expectations really liking the 17x9 all roundhttps://www.s2ki.com/s2000/public/st...lt/ponder2.gif maybe i should....
Originally Posted by Ned M
(Post 21085122)
I have the 17x8 / 17x9 staggered combination, using stock CR tire sizes 215 front / 255 rear. Absolutley no hint of rubbing during two track events and daily driving. My fenders aren't rolled. There's still room to go to a 225 or maybe a 235 section front tire. I don't think I'd try anything wider in the back without rolling the fender. Purchased from Tire Rack.
https://www.s2ki.com/s2000/uploads/g...703_790028.jpg https://www.s2ki.com/s2000/uploads/g...03_1261814.jpg https://www.s2ki.com/s2000/uploads/g...703_384154.jpg https://www.s2ki.com/s2000/uploads/g...703_120304.jpg |
(Post 21085416)
What offset?
I'm running 255s on all corners
Originally Posted by kamilio
(Post 21111293)
tire rack only has pf01 and not pf01r nor pf01ss. I have 215/45/r17 in front and 245/40/r17 in the back. I want a lip in front and back. Can I get a lip with pf01? Or where can I find wheels like the pf01r to buy
(Post 21111304)
WUT. to get a lip you have to go with 9s up front. i dont think the suffix letters (R/SS) necessarily transfer over accurately to the tirerack inventory. but everyone carries the same stuff and all pf01s in a given size have the same dimensions.
(Post 21114542)
will there be a problem fitting the 17x9 in front on a 215 tire? I want a lip on my car but I am scared the 17x9 will be too wide for the front and for the 215 tire, please let me know what you all think. Plus an offset of 60 should be good ?
(Post 21114652)
I'd go 235s on the front.
(Post 21156121)
Here are a few pics on the car:
17x9+60 with 245/45/17 tyres -3 degrees of camber in the rear and I think there is 2.5 in the front. http://i1102.photobucket.com/albums/...1-10153336.jpg http://i1102.photobucket.com/albums/...1-10153318.jpg http://i1102.photobucket.com/albums/...1-10153405.jpg There is a bit of "gap", so it's not "hellaflush" but overall it's a nice fit and looks good without looking ridiculous. |
Ok thats all of it.
Since I just got my set of PF01's installed this week, I figured I should post up some photos for those of you considering a set. This is a 2001 in Silverstone Silver, with black 17x9 +60 PF01's on 255/40R17 Bridgestone Potenze RE-71R's on all 4 corners...
https://cimg6.ibsrv.net/gimg/www.s2k...e512ed891.jpeg https://cimg1.ibsrv.net/gimg/www.s2k...73fe14081.jpeg |
