Where did the PF01 thread go? (It has been added to this thread)
#71
Site Moderator
Originally Posted by steve695' timestamp='1310618033' post='20777778
[quote name='prj3ctm4yh3m' timestamp='1310572126' post='20774882']
[quote name='steve695' timestamp='1310535141' post='20773678']
What do you mean exactly by durable?
[/quote]
Oh true, didn't really think of that.
I guess I'll have to be extra careful.
[/quote]
#72
Site Moderator
Will I rub on 17x9+60 with 255 tires all around with my car lowered to about a finger gap?
Can I achieve the required camber with the standard camber kit? I don't want to have to buy an aftermarket one.
My fenders are already rolled. (I don't know if this makes any difference with a +60 offset)
Will this setup improve the cars handling? I'm more concerned about handling than I am about looks.
And finally, if rubbing is going to be an issue, what can I do to resolve it?
With this offset there is very little chance of rubbing, especially if your fenders are already rolled. Most people with the +63 have had rubbing on the inside with the steering at full lock. The extra 3mm might be enough to avoid this.
There are numerous people on the racing forum that strongly feel nonstaggered is the way to go. They usually balance things out with a stiffer front sway bar since it will be easir to get the back end to comme out.
Yeah, I'm definitely going to run this set up.
It doesn't look like it's going to be a huge issue. I just get overly worried when I'm buying something from overseas, that it may not work when it arrives.
Yeah, I will get a front sway bar, they go for good prices on ebay.
If I feel oversteer is an issue, I may install a rear wing. However, I don't really like the look of wings on s2ks. The only ones I really like are the OEM lip spoilers, I doubt that these help with downforce though.
^Nice to both. No rubbing on the +48 even on the track? Is there very much caliper clearance up front?
Any idea what wheels, size, and offset these are?
http://www.waypast210.com/Other/NASA..._8Vd4cbB-XL-LB
#73
Site Moderator
Originally Posted by hatrickstu' timestamp='1311735352' post='20818926
Any info on fitting 48s on all 4 would be appreciated. Curious as to what has to be done up front
Basically, on the fronts run a 215 (if we are talking Star Specs et al) or 225 tire, run 2+ degrees of negative camber and manually push up/in the fender liner tabs a bit. Should have no problem with that.
On the rears, you will want a mild fender roll and a relocation of the tabs. If you dont, make sure youre close to stock ride height with 2.5 degrees of negative camber and 245 tires.
Originally Posted by prj3ctm4yh3m' timestamp='1311774643' post='20820055
255s on the front, Im sure you know already, require pulled fenders to avoid sucking off a fender liner and/or tab.
Originally Posted by hatrickstu' timestamp='1311775293' post='20820088
[quote name='prj3ctm4yh3m' timestamp='1311774643' post='20820055']
ive *seen* both up close simultaneously and there does not appear to be a difference in lip, but I did not get a chance to measure. The +60 at least has a substantial lip whereas my 8 +50 has none.
[/quote]
Originally Posted by prj3ctm4yh3m' timestamp='1311775416' post='20820099
[quote name='hatrickstu' timestamp='1311775293' post='20820088']
[/quote]
you're right. I had the 48s in mind and forgot to distinguish the 60s
[/quote]
#74
Site Moderator
Personally the black just isn't doing it for me. The wheels are so dark you can't see the spokes clearly. It's almost as if the wheel spoke design doesn't matter at that point because you can barely notice it. That's a shame since it's such a nice looking wheel. The silver looks much better, IMO.
I'd love a set of solid white PF01Rs for my Laguna blue. They have one, but it has a machined lip - a look I'm not a big fan of.
In real life, they honestly look freakin sweet!
My set arrived last week and I got the tyres fitted yesterday and then put them on. They look great on Silverstone. the +60 offset sits perfectly, only a little under flush with the guards.
Oh and just incase this info is any help to anyone:
I'm running 17x9+60 all aroud with 245 tyres all around and I do not rub, even on full lock. I am stock height at the moment but have coilovers being installed next week and will be going pretty low, I will report back.
Originally Posted by hatrickstu' timestamp='1312655283' post='20853892
Yea I wasn't a huge fan until I saw them in person. Truly a "pictures don't do justice" scenario
Well, I read the thread and really like the wheels. I will not do any fender rolling, pulling or tab relocation. I just want a set of wheels to put on the car.
It appears that the 17x9" +60 will fit with 255 all around with no rubbing on a mild drop. Which is what I am going for. I just want to confirm before ordering.
Sorry if it seems like a redundant question. Measure twice, cut once right.
Thanks for the help!
Originally Posted by prj3ctm4yh3m' timestamp='1313866258' post='20897516
Silverstone AP2 V1
Shine ASM Front Bumper
Koni/GCs
8/9 +48/+60 Sparkle Silver
#75
Site Moderator
Originally Posted by hatrickstu' timestamp='1313880182' post='20897941
Just curious why you went with staggered offset?
Originally Posted by hatrickstu' timestamp='1314104269' post='20904556
[/quote]
no they just push the axle back out so its at the right angle
#76
Site Moderator
i really like the new style of these wheels. i want to pick some up, was thinking about non-staggered after reading some other topics and think that the grip would be just crazy with 255 all round. if i went for a staggered set up with 17x8/17x9 what tire set up would be best 225/255 or 235/255? tire would be star specs. but i am seriously considering 17x9 all round with 255's, guess that would need the +60 offset or can you run them with +60(f)/+48(r) with little fender mods?. i use my car as my DD which is the better choice? As for colour choice i was thinking white with machine/lip on my BB not sure about the machine lip but worst case just get them powder coated if its a problem.
^Disagree. There is a look aspect to it. Yes the wheel face looks the same and you get no more lip but the car will look much nicer with the wheels sitting a lot more flush to the fenders. And this size is by no means pushing it as far as fitment goes.
I need to find someone to trade me a set of the 9 +48s for my 9 +45 rpf1s
215/245s with the star specs is pretty flipping big on a 8/9.
#77
Site Moderator
I have 17x9+60 and it sits nicely.
It isn't "hellaflush" but it does not look sunken in at all. It looks really good in my opinion.
Not to mention, I have no rubbing and I'm sitting pretty low.
17x9+60 is practical and looks fine, and you don't need to run as much camber. I'm only running 1.5 up back and 1 up front.
^ are you running 17x9 on all corners? have any shots from behind. cause i want to see a bit of rubber sticking out for that aggressive look . im running on stock wheels/tires lowered to a finger gab with a spring rate of 13 all round. think there will be any issues rubbing with a +60 17x9 and no roll in the rear? i would probably get the 17x8 up front not sure on offset
I will try and get some behind shots later
Originally Posted by hatrickstu' timestamp='1314913122' post='20936015
i posted pics, check them out
man you car is clean. love the spoon top, i always wanted one. your stance does look
thanks behind shot would really help.
but i guess i could just run a 10mm spacer or so if the stance isn't up to my expectations
really liking the 17x9 all round maybe i should....
I have the 17x8 / 17x9 staggered combination, using stock CR tire sizes 215 front / 255 rear. Absolutley no hint of rubbing during two track events and daily driving. My fenders aren't rolled. There's still room to go to a 225 or maybe a 235 section front tire. I don't think I'd try anything wider in the back without rolling the fender. Purchased from Tire Rack.
#78
Site Moderator
17x8 +50mm, 17x9 +60mm
#80
Since I just got my set of PF01's installed this week, I figured I should post up some photos for those of you considering a set. This is a 2001 in Silverstone Silver, with black 17x9 +60 PF01's on 255/40R17 Bridgestone Potenze RE-71R's on all 4 corners...
