Wider Fenders so What Wheels?
Ok so I have the ASM wider fenders in the front and the ASM rear overfenders ready for installation. But with these fenders of course means wider wheels, I've already decided on the 17" TE37's so...
...So with the fronts (it's +25mm each side) and with the rears (it's +25mm each side) how wide of wheels could I use to make them flush with these wider fenders???
I'm sorry but I never understood the wheel offset math stuff so any help would render MAJOR props
Don't have them yet, that's why I posted this, to figure out which wheel width size would be the widest I could use...was thinking about 17x9 in the front & 18x10.5 in the rear. Would this look flush with the fenders???
-also which offsets would I need?
i think with those fenders you could be in the mid to high 30s with your offsets (to be safe)...but your going to have to make sure that when you put the rear over fenders on that you cut out the original rear quarter panel or else you wont get a flush wheel in the rear...
