Need help with tire sizing with 18s TE37s
Just bought a set of TE37SL in GOLD. Size is 18*10 + 40 5x114.3
I test fitted the rims only and they fit but quite tight. Can someone tell me the best size tires to fit on these? pictures are attached. and best place to buy tires? Im in canada.
I really hope the rims arent too wide which will cause a lot of camber or rubbing issues. Actually really like these rims
That's way too wide.... You're probably going to have to run some super aggressive camber or a wide fender set up to make those wheels work.
My wheel specs are almost exactly the same as yours at 18x10 +39. I run 275 / 35 / 18 all around and they barely fit my widebody s2000.
Here is a picture of my car just for reference during its build. You can see from the second picture just how much it sticks out on a stock body.
I'm running 18x10 +39 and I also have spoon front fenders and asm rear overfenders and they just clear. You're not gonna get those on a stock body.
Site Moderator
Moved to wheel and tire.
There is no way those fit on the front. I don't know what world those "fit but are quite tight." The rear doesn't fit either unless you pull the hell out of your quarter panels and even then. I have 17x10 +35 and run asm rear over fenders and downforce front fenders with 255 tires. Then again looking at the other wheel in the pic and the super stretched tires you are probably the type of person thats ok putting 215's on a 10 inch wide wheel so you are probably wanting some very narrow stretched tire.
