Will 215/45 R17 Square Fit an 07 AP2 For Temporary Winter Use?
Hi,
I need to get winter tires this year, and my friend can sell me a set of four that are unused for cheap. They are size 215/45 R17. They wouldn't be used for spirited driving, just going 35 mph everyday to work and back in the Fall/Winter. Can I mount these on stock 2007 AP2 rims without safety issues?
Thanks!
Thanks!
No personal experience, but I believe this is the perfect size for a winter tire. Only "issue" would be a 215 tire on the 8.5" rear wheel. It will be stretched but should work fine. I'd look for a cheap set of 17 x 7" wheels all around for winter use.
Yes, it'll look a little weird though.
Hi,
Thanks!
Thanks!
https://tyrestretch.com/8.5-215-45-R...Pilot-Sport-2/
I'd have no concern about the stretch…I have concern that you've now reduced traction at the rear by going to a 215 F/R. In the snow/ice/cold.
Reduced rear traction is not ideal, even at 35 MPH. In the snow and cold and ice.
darcy
darcy
Is this really true? A wider tread patch would float over ice/water more easily, rather than digging in and creating traction, you would think.
The winter tire is designed to evacuate slush and aid in traction with all those snazzy snipes.
I do run a narrower winter tire on my civic SiR- i usually run a summer 205, but for winter, a 195. A friend of mine does 185 of his SiR. But ITS A CIVIC with FWD and it tends to more safely understeer as a rule, rather than oversteer.
keep the staggered set up- it will help maintain the balance the car is known for. Hey, its your car- do what you want- mount the tires up, go drive around a parking lot in the snow and rain and see what happens. Maybe we'll all be surprised and you'll be fine. I'm just telling you what I would do. Good luck.
darcy
danio
Southern Ontario For Sale
10-11-2012 11:03 AM
illiniknick
09-29-2012 03:53 PM
plutonium239
10-21-2007 04:48 PM
