will gram light 57s 17x7.5 and 18x8.5 fit?
Old 01-31-2013, 05:49 PM
efsf15's Avatar
Default will gram light 57s 17x7.5 and 18x8.5 fit?
Hey there guys I was wondering if there wheels will fit on my ap1 with koni yellows and stock springs. Offset is +40 in both from and rear. Tire size is 225/45 in front and 255/40 in rear. Please if someone can get back to me that would be great!!!
PS.. my car is running UK alignment if that would effect anything.
Old 01-31-2013, 10:20 PM
efsf15's Avatar
any help would be great!!!
Old 02-01-2013, 10:46 AM
Site Moderator
Manga_Spawn's Avatar
Same exact answer I gave in your other thread. You will need to roll the front (since the rear is rolled) relocate the rear tabs and possibly run a little more camber. If you are at stock height though I think it is going to look goofy like you are off roading. You will definately have to get the height dialed in after you put the wheels on.
Old 02-01-2013, 04:14 PM
ryuken's Avatar
255/40 on an 18x8.5 is going to look meaty unless that is the look you're going for. I suggest a 255/35 for the rear to keep the diameter the same as the fronts. And if you don't want the tire to bulge out of your wheels you can go for 215/45/17 for the front and 245/35/18 for the rear. It'll sit square. You'll still have to modify your fenders all around so they don't rub.
efsf15
01-31-2013 05:46 PM
06S2000speed
12-19-2009 11:59 AM
fishs2000
07-26-2008 11:44 AM
asnkasper
02-25-2008 07:52 AM
cornercompacts
03-30-2007 07:08 PM
Quick Reply: will gram light 57s 17x7.5 and 18x8.5 fit?
