Will TC105x 17 9.5J ET45 fit ar AP1 front and rear with roll fender ?
Does it fit in ? And how camber should set up? thanks |
Front will need a small pull at minimum.
Yeah fronts don't really fit unless you run stretched tires and camber. Rear can work though just needs to be rolls flat, tab relo and camber. I'd go a little narrower in the front (or a higher offset) if you are wanting to run a proper width tire.
Thanks for the comment I have ordered 17 9.5J +45 X 4 and wanna to use 255 does any have experience on S2000 how much camber I need to adjust at front and rear ? |
Dude you need to do research. This has all been covered.
Look up what people have done to fit 17x9.5 +47 CE28, 17x9.5 +41 TE37, 17x10 +50 RZII, and on and on. Every tire is going to change the numbers too. With my tiny pull, I can fit my 9.5 +43 with 255 rivals......unless I were to hit a bump while turning and blow up my fender. |
Lol yeah generally best to actually research before just buying wheels for a car you're not familiar with. You'll need a pretty good pull and likely -2.5 to -3 camber in front. Like Cody said it will depend on the tire as tires vary quite a bit. Good luck with that.
