Will TC105x 17 9.5J ET45 fit ar AP1 front and rear with roll fender ? - S2KI Honda S2000 Forums
Go Back  S2KI Honda S2000 Forums > Special Interest > Wheels and Tires by The Tire Rack
Reload this Page >
Notices
Wheels and Tires by The Tire Rack Discussion about wheels and tires for the S2000.
Old 12-12-2018, 03:05 PM
Default Will TC105x 17 9.5J ET45 fit ar AP1 front and rear with roll fender ?
Does it fit in ? And how camber should set up?
thanks
AnsenLi is offline
Old 12-12-2018, 05:59 PM
TsukubaCody's Avatar
Front will need a small pull at minimum.
TsukubaCody is offline
Old 12-14-2018, 12:24 PM
Site Moderator
Manga_Spawn's Avatar
Yeah fronts don't really fit unless you run stretched tires and camber. Rear can work though just needs to be rolls flat, tab relo and camber. I'd go a little narrower in the front (or a higher offset) if you are wanting to run a proper width tire.
Manga_Spawn is offline
Old 12-18-2018, 12:29 AM
Thanks for the comment
I have ordered 17 9.5J +45 X 4 and wanna to use 255
does any have experience on S2000 how much camber I need to adjust at front and rear ?
AnsenLi is offline
Old 12-18-2018, 04:37 AM
Dude you need to do research. This has all been covered.
Look up what people have done to fit 17x9.5 +47 CE28, 17x9.5 +41 TE37, 17x10 +50 RZII, and on and on. Every tire is going to change the numbers too. With my tiny pull, I can fit my 9.5 +43 with 255 rivals......unless I were to hit a bump while turning and blow up my fender.
Old 12-18-2018, 08:49 AM
Site Moderator
Lol yeah generally best to actually research before just buying wheels for a car you're not familiar with. You'll need a pretty good pull and likely -2.5 to -3 camber in front. Like Cody said it will depend on the tire as tires vary quite a bit. Good luck with that.
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
