special tools for wheel bearing replacement
For those of you who do this procedure yourself ( and presumably you do it quite frequently if you go to the track a lot ), do you buy the special tools needed to press the bearing out and then in, or do you rely on a nearby shop to do that? I'm in SoCal O.C., and many shops here can do that for me, but I prefer to just rent a service bay with a good one-post lift and use my own tools to do everything myself. The shop will have a press available, but likely not the necessary special tools. I have the ball joint removal tool and have used it several times in the past, so that part of the procedure is fine with me.
The procedure is described in the manual in the attached pdf.[attachment=37767:S2000 Front Wheel Bearing Replacement.pdf]
Here is a write-up on honda-tech.com of an alternative method not using a hydraulic press:
Front Wheel Bearing Replacement with Harbor Freight Tool Set 66829
snwbrderphat540
Mar 27, 2015 09:50 AM
sandiegan
Jun 6, 2012 09:21 AM
bluesaint
Oct 4, 2006 03:38 PM
