Sponsor S2000 Engine and S2000 Drivetrain Deals Sponsor deals on S2000 engine and S2000 drivetrain products
CNCSpeedshop Signature short blocks
Old Aug 28, 2013 | 04:35 AM
wadzii's Avatar
Banned
Default CNCSpeedshop Signature short blocks
Our signature short blocks are built to order with the best parts on the market
We start with a core block, install Darton ductile iron dry flanged sleeves, the block is honed to our specs, then decked and cleaned.
Our blocks include Wiseco pistons, Brian Crower rods, ACL bearings and are blueprinted to ensure proper oil clearance on all bearings.
Signature short blocks are $2899 including 5 quarts of Amsoil Break in oil
Core blocks are $350
Core Cranks are $350
At this time we do not have any cores available.
Dyno results from one of our 9:1 compression long blocks with an RLZ CNC cylinder head. Car was on the dyno for break in before the turbo is installed.
Old Aug 30, 2013 | 07:13 AM
f20kills's Avatar
Nice!
I have a complete 2.2 long block that had crank walk. I picked it up for dirt cheap (mainly for the head) but in your experience, can the bottom end be saved (rebuilt)?
Old Aug 30, 2013 | 07:27 AM
wadzii's Avatar
Banned
It depends.. if the thrust washer just wore out then we can rebuild it no problem. If the thurst washer spun in the block then the block and crank are probably toast. If it just wore into the crank then we can probably reuse the block.
Did it lock up or could you just see the crank moving back and forth a little?
Old Aug 30, 2013 | 07:34 AM
f20kills's Avatar
Some of the thrust washers ended up in the pan and I didnt try too hard but it seems like its locked up.
I havent had time to open it up and the guy I bought it from didnt even bother with it either lol.
Once I get it open I can get a better idea (pics too). Maybe this weekend I can work on it.
Thanks for the quick response
Old Aug 30, 2013 | 07:38 AM
wadzii's Avatar
Banned
Shoot me some pictures once you have it opened up and we'll see whats going on. It sounds like it spun the thrust washer in the block. I'm sure the block will be unusable. If you're lucky the crank is ok.
Old Aug 30, 2013 | 07:47 AM
f20kills's Avatar
Perfect! Thanks agian
Old Aug 31, 2013 | 07:59 PM
f20kills's Avatar
Yeah...block looks f'd. Crank I can't tell and would need someone with experience to make the call. On the plus side, head was perfect.
Old Nov 25, 2014 | 03:19 PM
ZSAK's Avatar
Do you guys still do engine builds for turbo application?
Old Nov 25, 2014 | 03:24 PM
wadzii's Avatar
Banned
We can take care of pretty much any engine build you need
liquid_helix136
Feb 20, 2017 10:38 PM
hammerhead300
Sep 25, 2013 10:49 AM
supertech
Jul 29, 2010 04:54 PM
owenxguo
Jun 26, 2006 11:11 PM
S2KJimmy
Sep 19, 2005 06:51 PM
