Aem user cold start problem
Old Nov 3, 2013 | 03:45 PM
s2kseven's Avatar
Default Aem user cold start problem
Do you know what adjustment i need to do to change my AEM EMS to start a little bit better during cold start?
Is it somewhere in my coolant temp parameter?
Summer time, I don't have problem in starting -- but now it's getting cold here in the northeast, i have to crank - crank - crank more crank to start the car.
thank you
Old Nov 3, 2013 | 07:39 PM
tom153's Avatar
Engine start > Advanced start > Initial crank pulse table
Bump it up in the coolant temp sections which you see on a dead cold engine. Give it three bumps up first and then test again the next morning.
Old Nov 3, 2013 | 07:50 PM
tom153's Avatar
Also, check your injector pulse width at idle when your engine is warm. Then, adjust your Crank Injector Time table (Engine start > Crank Injector Time table) until your pulse width is about 4 times the amount you saw at idle. Ie. if your pulse width is 2000 uSec at idle, adjust your CIT at 0 throttle and engine off until your pulse width is 8000 uSec. You can see this in the parameters window of your "tuning" tab (Fuel Inj #01 Pulse).
Old Nov 4, 2013 | 02:23 AM
s2kseven's Avatar
thanks tom - i will try the first one first - if still the same, i will do the second step.
i will do it gradually,
Old Nov 4, 2013 | 04:07 AM
tom153's Avatar
Sure thing. You kind have to have both set up and then you really tune cold starts with the ICP table.
nguyen365
Apr 11, 2018 07:47 AM
jh4db536
Oct 28, 2017 07:27 AM
hondabim
Apr 5, 2010 02:26 PM
tonerockyhorror
Jan 23, 2006 11:15 AM
DrStuff
Dec 6, 2002 07:03 AM
