What glue for soft top patch?
Old May 23, 2014 | 06:10 AM
P1h3r1e3d13's Avatar
Thumbs up What glue for soft top patch?
I have a small (½") tear in my soft top that I'll be patching with a bit of spare top material. What sort of adhesive should I use to attach it?
Candidates are:I've also read talk of silicone adhesive or superglue.
The tear is right where it folds, and I put the top up and down several times a day, so flexibility and strength are both important.
The tear is only a couple millimeters wide, but I also want to fill in the gap from outside after it's patched and I don't want it to look too obvious from outside. Should I use the same stuff or something else? Somebody on here found a kit with some kind of goop that came in different colors and blended it to match, but I can't find that now.
Old May 23, 2014 | 07:59 AM
Saki GT's Avatar
I'm using the Locktite stuff now - it seems to last about 3 months before giving out and needing to be redone due to use and wind pulling at it.
Old May 23, 2014 | 08:18 AM
vtec9's Avatar
E6000.
1) sew the rip shut
2) glue on the patch eith E6000
Alternately, use gorilla tape! On the inside. One piece will last a year with many many top folds. And it's insanely easy to replace, obviously. I've had the same piece on my rip since Aug 2013, and it made it though New England winter just fine.
Old May 25, 2014 | 04:46 AM
deepbluejh's Avatar
Gorilla tape doesn't work at all. Don't even waste your time.
I've used RTV silicon on my patches with moderate success.
Old May 25, 2014 | 07:09 AM
Themikewoo's Avatar
E6000: how long do you guys hold pressure? I need to glue an oil piece of soft top (spare soft top) onto my current soft top with a small tear that hasn't completely gone through. Tried a test strip (old soft top glued to old soft top) and after a few hours it can be easily peeled apart. Tried both sides, outside and inside.
I am thinking maybe the ambient temperature is not warm enough (23 degree's Celsius).
Old May 26, 2014 | 12:51 PM
slomaro3.4's Avatar
I had a small tear, loctite glued it, stitched it up, then slathered it in some flexible waterproof vinyl glue I had laying around. Seems to be holding up, but in all fairness it doesn't rain much in SD.
Old May 26, 2014 | 01:16 PM
Hooray for SD! That's how I justified getting summer tires for a daily driver.
Does your fix stand out visually? Are the loctite and the vinyl glue black or clear?
Old May 26, 2014 | 03:35 PM
slomaro3.4's Avatar
They are both clear, and I used black wax coated thread, so it really doesn't stand out, for me it was such a small tear that I couldn't justify dropping $1300 on a new top. Just remember if you are fixing the top to be careful, a bad stitch job could make things worse over time.
Old May 26, 2014 | 03:41 PM
taifei's Avatar
how does E6000 stand up to the heat? does it soften up enough for the patch to get caught and drag or does it pretty solid once it sets?
Old May 26, 2014 | 07:49 PM
s2ka's Avatar
Black Shoe Goo works good.
https://www.s2ki.com/s2000/topic/548...d-maintenance/
