S2000 Projector differences
Old Jun 12, 2014 | 10:01 PM
Iradier310's Avatar
Default S2000 Projector differences
Okay so everyone knows s2000 projectors are some of the best out there.
There is actually 3 different versions ap1, ap2, and 06+ ap2.
I recently bought a 2007 s2000 and I don’t really like my cutoff. It’s not that sharp and doesn’t have much color.
I was thinking about swapping out my projectors with ap1. Has anyone ever done that?
Here is where I found out the information. (Along with pictures)
S2000 Projector Differences
Ap1 Sharp/traditional step. (04-05 is similar)
Ap2 06+ Triangular/slope step thing.. not as sharp.
Old Jun 13, 2014 | 12:36 PM
bendang2005's Avatar
That explains why mine (07) didn't seem as sharp as my brother's s2k (05)......doesn't sound like a cheap swap. Good luck.
Old Jun 13, 2014 | 01:00 PM
Iradier310's Avatar
Well TRS sells ap1 projectors for $325 and I can probably sell my ap2v2 projectors to help offset the cost.
It’s not a huge deal, but I do want a sharper cutoff line and traditional step vs the new one.
Old Jun 13, 2014 | 04:03 PM
MBHs2k's Avatar
The 06+ projectors have a different part number?
Old Jun 14, 2014 | 01:10 AM
Iradier310's Avatar
Just checked on Majestic Honda and it is different part numbers for 04/05 headlights vs 06/07/08/09.
Old Jun 14, 2014 | 10:13 AM
jetboater's Avatar
I noticed a difference between my '05 and my '07. The '05 definitely had a sharp cutoff along the top edge of the light pattern and, on a dark road, didn't light up anything above the cutoff or at further distances.
The '07 has a "softer" edge that lights up further down the road and lights up street signs much further away. As the '05 would go over bumps at night, the upper edge of the light seemed to "bounce" up and down which I found annoying and this isn't noticeable on the ''07 with it's softer upper cutoff edge.
The cutoff difference is probably not very noticeable to anyone except the driver and then I only noticed it in back to back drives when I had both the '05 and the '07.
It's purely personal preference but I like the '07 pattern better as I like the longer distance it seems to light up.
Others may differ in their opinions!
Old Jun 14, 2014 | 10:53 AM
Gotpepsi's Avatar
We should post pictures to compare and contrast the cut off so people understand.
Old Jun 14, 2014 | 11:01 AM
BrettVisionSLR's Avatar
Good info jetboater. I find the same issues you mention, and it's especially an issue on winding mountain roads where my vision is restricted during left turns, especially climbing lefts. I need a car ahead of me if I want to see what I'd see in most cars with the high beams on.
I was hoping that it was just a matter of angling the high beam up and left a bit, but AP2V2 lights may be a better solution in general. I suspect the V2 lights also reduce the "flashing" that oncoming traffic or cars ahead of me perceive if they really do have a softer transition
Old Jun 16, 2014 | 10:58 AM
Kenshyn's Avatar
Interesting info.
Good thread.
Old Jun 16, 2014 | 08:27 PM
muamer's Avatar
It's the lens.....
Www.hidplanet.com
Read there
