Chance S2K's "S2KI Rejects" Turbo Build
Hey everyone My shopping list for my turbo S2000 build is getting very short and I'm hoping to start actually assembling the build sometime in the next couple weeks. End results I'm hoping for is a 460-480WHP, reliable daily driven S2000 that is also useful for the occasional track day or highway/quarter mile pull. It's a tall order, but I have high hopes
I spent a lot of time scoping out the FI sales threads looking for good deals, and most of the parts I'll now be using in this build were bought used by members on this site. So I've accumulated all the "rejects" :
Turbo:
Borg Warner s256 “Bullseye” T3 .70A/R (Purchased from lude92_si)
Custom Fabricated 2.5” Intercooler Piping (Purchased from kaptaink2002)
CXRacing 700HP 31x11x3 Intercooler
TrackForged RamHorn Manifold, 3” downpipe, 1” External dumptube (Purchased from uLmighty)
Berk Headerback 3” Exhaust
Vibrant 3” x 6” Flex Pipe
Greddy RS BOV (Purchased from Suzuka_Joe)
Tial MV-R Wastegate 44mm (Purchased from Stantaur)
Oil Feed Kit
Canton Oil Filter Relocate (Purchased from Jim Bravo)
Fuel System:
FID 1000cc injectors
Full Blown 290LPH Fuel Pump
Drivetrain
Competition Clutch Stage 4
Electronics:
AEM EMS V2
SoS 3Bar MAP Sensor (Purchased from alaskas2000)
SoS Pillar Gauge Set AFR/AEM Serial (Purchased from alaskas2000)
Other:
T1 Dual Oil Catch Can (Purchased from Minitoyota)
3 Port Powdercoated Valve Cover (Purchased from Minitoyota)
PTP T3 Turbo Blanket
PTP Adhesive Heat Shielding (Fuse Box/AC Lines)
DEI Heat Wrap Manifold/Downpipe
Treadstone Turbo Gasket/Bolt Kit
Bridgestone Potenza RE-11 245/45R/16 (rear)
NGK BKR8EIX Spark Plugs
At the time of posting this, the only two items that still need to be purchased are the AEM EMS and an oil feed kit for the turbo. Currently the fuel injectors, heat shielding materials, gasket/bolt kit, and spark plugs are on their way in shipping. I'm also replacing all gaskets that will be removed, as well as using a Cometic 3 layer gasket on my turbo manifold in order to try to stop what appeared to be a previous exhaust leak on it
With this build I've tried to save as much money as possible (lol) by buying used parts and trying to reduce costs in areas without "cutting corners". I want to try to keep this build relatively cheap, but not at the cost of reliability.
All crucial fluids will be replaced with quality synthetics. The transmission fluid has already been replaced with Amsoil 5w30 Synchromesh, and the diff has been refilled with Amsoil 75w140 per Puddy's recommendation
Currently the CC clutch and Berk exhaust are the only things installed on the car. I've just finished breaking in the clutch, and have finally gotten (mostly) used to daily driving a 6 puck ceramic clutch. The Berk headerback sounds awesome at lower RPMs and has a good aggressive growl to it's note, and at higher RPMs it absolutely screams. The only downsides to the exhaust is a pretty significant drone between 3K-4K, and some bad rasping when de-throttling from high RPM. I've heard a resonator can remedy this, but it's not currently bothering me enough to do anything about
I have a good friend helping me out on this build, and without his help none of this would be possible!
Here are some pictures of the parts and progress so far on the car:
Fun fact: According to an employee at TrackForged, only 3 of these ramhorn style manifolds were ever sold.
If you zoom in, you can see how bad some of the fins are smashed/aligned already. I'm pretty sure this will still suffice though.
Pictures from the Clutch Install:
Pictures of the car as it currently sits (somewhat clean for once!)
I'll keep this thread updated as the last few parts come in the mail, and of course when I finally get to start putting everything together . I'll be sure to include a "dyno" and "first ride" video as well.
If anyone has any input, questions, or suggestions for this thread feel free to post!
Turbo:
Oil Feed Kit
Fuel System:
Drivetrain
Electronics:
AEM EMS V2
Other:
It's definitely a PITA. Between me and my friend doing this for the first time, we collectively spent probably about ~20 hours working on the car. A huge portion of that time was spent trying to remove the top two 17mm transmission housing bolts close to the firewall (we ended up lowering the entire subframe in order to get better access). Putting everything back together was actually much easier than taking it apart lol.
That being said, I'm pretty sure the labor cost of getting something like this done at a shop would be insanely high (plus I just don't trust most mechanics), so I'm really glad we did it ourselves.
Originally Posted by dustin02rsx' timestamp='1413846018' post='23376531
How bad did that clutch install suck using jack stands? I'm debating on doing mine myself or not for that reason.
Originally Posted by Chance S2K' timestamp='1413846712' post='23376539
[quote name='dustin02rsx' timestamp='1413846018' post='23376531']
[/quote]
Thanks man
Yeah, once we finally lowered the subframe everything went quite a bit smoother. So much of the car has to come apart just to access the clutch, it's just a very tedious job.
I have a lot more stuff coming in the mail over the next couple days, so I'll update with a few more pics shortly. The actual "build" portion of this will probably start around Thanksgiving, since I'll have a few consecutive days off from school and hopefully work as well. I'm going on a small ~300 mile "road trip" in a couple weeks too and I need the car for that, so I don't want to take it apart yet
Edit: Oh, I should also have some 245/45/16 Potenza RE-11's going on the rear of the car in the next couple of days.
