Cars2kman's CNCSpeedshop 2.4L build
Banned
Thought I'd share a build we did here recently. We installed our 2.4L stroker kit into a relatively stock ap1. The motor was in really good shape so we reused the stock ap1 pistons, installed new 06+ rings. The car still has the stock throttle body, intake manifold, injectors, cams and header. We also gave him a slight clutch upgrade, stock pressure plate with our custom unsprung organic clutch disk from ACT.
Stock Ap1 Pistons
CNC Speedshop 2.4L stroker kit
ACL Race bearings
Supertech Beehive valve spring kit
Fujita cold air intake
Unknown High flow cat
70mm exhaust
RLZEngineering CNC ported head
Stock throttle body
Stock Intake manifold
Stock injectors
Stock cams
Stock header
Tuned by us with AEMv2
And for the dyno graphs
This is compared to an ap1 with only K&N intake, 70mm test pipe and 70mm exhaust
For more info on the stroker kit check out our group buy thread https://www.s2ki.com/s2000/topic/111...2-group-buy-2/
Stock Ap1 Pistons
ACL Race bearings
70mm exhaust
Stock throttle body
Stock injectors
Stock cams
Stock header
Banned
I just realized you cant see the rpms on the dyno.. I'll get a new one up here shortly.
The rev limit is set at 8500, with the stock throttle body and intake manifold choking everything up it peaks power at 8000.
So with the AP1 pistons, this motor is at 13:1 compression? How is pump gas coping with that? Did you have to retard timing or go more rich? Any ideas on how to lower compression down to a safer level for FI options on a 2.4 stroker? Any thicker head gaskets out there that are reliable like OEM?
Well just wrapping up the forth day of driving, its still early on and shes running very well. I've had her about two years now been lurking on the forum just about every night, and feel I've learned alot about the car from here. I decided to go with the 2.4L build because I wanted to stay NA, felt that if I could get close to 300whp that would be enough for me.
I had concerns about the longevity of the motor and spoke with Wadzii about it and the 13.1CR, obviously he felt the motor would have longevity and run safe. Time will be the deciding factor in that. I'm satisfied with my decision, Wadzii is a very capable engine builder along with being someone that shares knowledge, and is easy to talk with, he knows that when he puts his name on it and posts it up on the forum his rep is at stake. Also his partner Cameron let me know how things were coming on the build, the month of February was kinda tough weather for us southerners, so it took alittle longer than we expected but Cameron kept me up to speed on the progress. All I can say right now is that she will fly, I know she's not in the boosted HP catagory, but even running 80 in sixth gear and put your foot down it starts to pull, in any gear its instant. Next up will be the test pipe for the extra low end tq the current HFC is a Berk, and when the finances line up I'll start researching the intake manifold and throttle body additions. Well......... don't have the finances but the research started last night.
