HELP needed please - loose harness wire to AEM EMS 2
Old May 23, 2015 | 01:39 PM
Chiung's Avatar
Default HELP needed please - loose harness wire to AEM EMS 2
I have a KW SC kit that I didn't install. I bought an alloycraft EMS bracket and went to install it. In the process of pulling the 3 harness connectors out of the EMS I may have pulled a wire out of the connector.
I say may have because I was pretty careful prying the connectors out of the EMS without tugging on the wires. I used a flat-blade screwdriver to pry. Anyway, they popped out and then I noticed this loose white wire. It looks like it used to go in the blue connector.
Also, my AEM UEGO WB gauge has a white wire that goes into the blue connector.
Here are pictures. Does the white wire (the loose one with the silver pin on the end need to be going into a connector? If so, where does it go and do I just slide it in?
Thanks
[attachment=79790:20150523_160500.jpg]
[attachment=79791:20150523_160702.jpg]
[attachment=79792:20150523_160651.jpg]
Attached Thumbnails HELP needed please - loose harness wire to AEM EMS 2-20150523_160500.jpg   HELP needed please - loose harness wire to AEM EMS 2-20150523_160702.jpg   HELP needed please - loose harness wire to AEM EMS 2-20150523_160651.jpg
Old May 23, 2015 | 02:12 PM
AFs2k's Avatar
That's the factory o2 sensor wire. They removed it because it's no longer used. They used the spot where it was to input the AEM wideband.
There is nothing to worry about here. But you do need to either put some electrical tape on it or some shrink tube over it to protect it. Do that and forget you ever saw it.
Old May 23, 2015 | 02:41 PM
Chiung's Avatar
Thanks I thought I was so screwed.
On another note - going to relocate my WB from pillar to behind radio door but cables not long enough. Does AEM sell extensions?
Also, going to add a serial gauge - where does it plug into the EMS?
Chiung
May 23, 2015 02:15 PM
jb34304
Jun 5, 2010 04:21 PM
Suzuka_Joe
Feb 2, 2010 08:17 AM
S2KSuzuka
Jun 26, 2007 09:02 AM
ideugene
Apr 17, 2006 07:40 PM
