Fitting smaller wheels and tyres?
I'm currently toying with the idea of swapping my standard 2009 17" wheels on Bridgestones (215F 245R) for some very light OEM JDM BBS 16" wheels with 205/50 front and 225/45 rear AD08R's.
This combination gives a smaller overall diameter and narrower tyres front and rear but the wheel and tyre combination will save around 5kg per wheel.
I know most people fit larger tyres but to me my 2009 S feels a little heavy and over-tyred.
I'm not after ultimate grip, I know this will probably go down, however I am after higher agility, better composure over bumps and just trying to get rid of that big tyre feeling, especially on the rear, that it currently has.
Any comments, experiences of this setup, good or bad?
I'd fit the correct size tyres with those lovely wheels. The JDM BBS are very light and do make a considerable improvement to the ride and steering. Whether or not they will work on a later car which is designed for the larger wheels, I'm less sure but someone in the know may be able to make a more informed comment.
I have that wheel and tyre size on my track car and it puts the speedo out by about 14mph at a gps recorded 100mph
Also it doesn't improve the ride quality as you still have a similar sidewall height, I only went for this option as I wanted 16" track tyres and not many companies make them in 16" to fit the S2000.
Also as mentioned it does take a bit of getting used to looks wise, however I don't really care about that personally.
Ive just got a set of these wheels from Japan. I've decided to go with Lovegroova's advice and fit std. size RE002's.
Looks like I'll be saving 16kg's total of rotating mass vs my std. 2009 wheels and tyres.
...they say rotating mass is worth 4 x static mass, so I'm going to be losing the weight of a passenger :-)
