PRM Install
Old Oct 30, 2003 | 12:04 PM
ChrisWells's Avatar
This is really simple thanks to the help provided by PJG.
First pull out the old air box. I won't go into further detals on this as you just pull it all out
Next, plug the PRM together. You can use the kiddy drawings provided or just use common sense.
There is a bracket situated near the front where the funnel will sit and I taped some polystyrene to this to ensure that he PRM didn't bang about.
To install the PRM, first connect the thick hose to the top of the cover:
There should be a small unit dangling about. You will need to drill out the fixing hole to a slightly larger size to take one of the old airbox fixing bolts. Once you have done this, bolt it on to the cross member:
Then replace the two small tubes with the ones supplied. The end that disappears plugs into the small unit:
Now fit the PRM, use the plastic ring and clamps to bolt it on:
The finished item should look like this:
Hope this helps.
Apologies for the quality of the photos but it was cold, wet and dark
Old Oct 30, 2003 | 12:06 PM
AquilaEagle's Avatar
Administrator
Very nice Chris A good helpful write up too
Old Oct 30, 2003 | 11:39 PM
Ian_km's Avatar
Looks just like mine
Following on from this, has anyone cleaned their filter yet, if how how did they go about it ?
Old Oct 31, 2003 | 01:28 AM
GSi's Avatar
GSi
There is another way !
Will post some pics one day. You can reuse the original S shaped metal tube rather than completely bypass it..
BTW.. That whites quite tasty... There is at least one grade 5 or 6 white s2k coming up every day on the auctions. One day I will bite the bullet.
Old Oct 31, 2003 | 02:18 AM
STAVLAD's Avatar
Dose anybody know if the PRM voids the warranty??
I wanna get one but not sure if its going to affect it.
Paul
Old Oct 31, 2003 | 02:52 AM
GSi's Avatar
GSi
I fitted mine myself and have just this morning collected my car from serveral days of head gasket replacement - lots of dosh - all covered under warranty - not even a mention of the PRM
Old Mar 30, 2004 | 03:11 AM
JamieS2K's Avatar
[QUOTE]Originally posted by STAVLAD
Old Mar 30, 2004 | 03:13 AM
JamieS2K's Avatar
Whoops a bit of an old thread !!!
Old Mar 30, 2004 | 04:32 AM
Administrator
link to tech faq?
Old Jun 23, 2005 | 01:46 AM
Sundance's Avatar
Do you need to adjust the bonnet catches as a result of adding a PRM?
How much does one of these cost?
Cheers,
Ash
