Rear speaker cutout
Old Mar 2, 2005 | 05:32 AM
QP_CH's Avatar
Default Rear speaker cutout
I would like to add the infinity ref 5000cs (only 5.25" main speaker) in the plastic panel behind the seats. Because this is not much work and the shipping costs for a "lucid" panel is to high (switzerland) here is my question:
Could someone give me the exact measurements of the center of the circular cutout I have to make in this panel (measurements in cm pleaaaase )
Measurement from bottom of panel: ???? cm
from side of panel: ???? cm
Old Mar 2, 2005 | 09:28 AM
darkknight1999's Avatar
I don't have exact measurements but you can see exactly where you want to cut the holes into the panels.
I hope that helps a little.
Old Mar 2, 2005 | 11:48 AM
BocaS2000's Avatar
I did my rear panels myself using a Dremmel. It was simple and I am by no means a professional audio / car person. I suggest using the pics that darkknight1999 posted as a reference. Also, if your speakers are new, the box should have a cardboard cut-out (or make one) so you can draw your circle on the panel. Good Luck!
Old Mar 2, 2005 | 09:01 PM
1fastminivan's Avatar
so is there a hole in the rear for the speaker magnet to fit in?....
Old Mar 3, 2005 | 01:52 AM
Some speakers just fit others you need to trim the sheet metal behind the plastic. I needed to trim a little to make them fit.
This is the only picture I have loaded up that shows behind the plastic:
Old Mar 3, 2005 | 04:34 AM
AusS2000's Avatar
The way I did it was to make up a cardboard copy of the panel to test fit with. I could muck around with it until I got it right, then use it as a template on the real panel. Do the other side by flipping the template.
Old Mar 6, 2005 | 05:51 PM
JSfetko's Avatar
I have the Reference 5000 componets in the rear. I used the trim mounting ring as a template against the panel, placed as far down so as not to cut off the bottom of panel and as far to the outside and still be able to remove the mounting panel hook.
Some slight metal cutting was required for magnet to clear. I modified Darknight1999's picture since I don't have one where I had to cut. The 2 red angled lines are the cuts made from the center hole then hammered inward.
Old Mar 22, 2005 | 07:27 AM
Darien1629's Avatar
dont the seats muffle the speakers
Old Apr 6, 2005 | 07:10 AM
sf_firestarter's Avatar
Originally Posted by JSfetko,Mar 6 2005, 06:51 PM
Has anybody installed speakers into that square padded panel at the bottom or in the bottom of the roll hoop panels in the flat open area? I've searched for photos of various install locations but all I can find are photos of the same "lucid mounting location." Is this the only option?
Old Apr 6, 2005 | 09:28 AM
http://pg.photos.yahoo.com/ph/evanwambeke/...9f5.jpg&.src=ph
sorry, don't know how to post pics correctly so here is a link to a photo with illustration
PAS2KNut
Aug 3, 2016 12:01 PM
NJSY2K!
Dec 18, 2006 07:12 AM
s2k paradigm
Mar 4, 2004 07:01 AM
145
Mar 10, 2003 08:53 PM
ianl
Sep 10, 2001 01:24 AM
