UK ALIGNMENT
Old Jun 9, 2006 | 10:44 AM
Swiftoy's Avatar
Default UK ALIGNMENT
I was just wondering what is achieved by going to the UK specs, more lateral grip more neutral feel more or less oversteer or understeer? Can someone enlighten me a bit more.
Thanks, Swiftoy
Old Jun 9, 2006 | 11:22 AM
diabolus2k's Avatar
bump for this as I'm curious as well
Old Jun 9, 2006 | 11:42 AM
slimjim8201's Avatar
Pros:
Added cornering stability, maximum grip and transient response. Amazing feel.
Cons:
Slightly increased tire wear, less straight-line stability.
IMHO, the pros far outweigh the cons.
Old Jun 9, 2006 | 11:45 AM
Emil St-Hilaire's Avatar
Active Streak: 30 Days
Less oversteer,and less prone to "snap oversteer".!!!
Old Jun 9, 2006 | 11:59 AM
SpitfireS's Avatar
UK specs allignment make you drive on the "wrong" side of the road.
Like they do in the UK.
You know.. wrong <=> right
But I'm going to get that setup as well
(as soon as the new shocks arrive and are installed)
Old Jun 9, 2006 | 12:53 PM
Helios's Avatar
The rear end stays better planted around corners, while straight-ahead steering loses just a little sensitivity. The steering seems a bit slower, less "go-kart" like, but is still responsive.
This was what I noticed in my '02. I can't speak about AP 2 models.
Old Jun 9, 2006 | 01:15 PM
RED MX5's Avatar
For me the UK specs were an attempt to get better control during rapid transitions, and during spin correction. With the stock alignment there were times when correcting a spin only resulted in a spin in the opposite direction. By moving the bias more toward understeer (less oversteer) the UK alignment made this much less of an issue. I can push the car much harder now, with much greater confidence.
Turn-in isn't as sharp, but that's actually a plus too, as it makes smooth turn-in just that much easier.
Anyone who drives the car hard should at least *try* the UK specs. Increased tire wear is the only downside, and IHO it's a good tradeoff.
Old Jun 9, 2006 | 03:04 PM
aronparsons's Avatar
The extra tire wear is minimal though as the UK specs aren't really that aggressive (-1.0 camber, slight toe-in in the rear IIRC). I'm surprised at how little negative camber is set for a stock alignment (-0.5 IIRC).
Old Jun 9, 2006 | 03:12 PM
S2K:-)'s Avatar
I've got it and I LOVE IT. Helped me out in auto-x's. I used to have my back step out alot, and now it's more controlled.
Here is how I set mine up: (Wish I could have done -2.5 camber in the rear though...)
Old Jun 9, 2006 | 03:26 PM
sund's Avatar
Are there different alignment specs for the AP2 vs. the AP1?
