Engine block oil leak ?
Old Feb 20, 2008 | 02:35 PM
Apex_AP1's Avatar
Default Engine block oil leak ?
So I noticed some dry oil around the crack of my engine block. Between the red stock cover and metal bottom half. Is this normal to see a little bit of oil by the crack areas on the front and side? Car performs and sounds fine though. And I never overfill my oil when I add any.
Old Feb 20, 2008 | 02:57 PM
jyeung528's Avatar
my friend has this also...
no clue.
Old Feb 20, 2008 | 03:00 PM
J'sS2K's Avatar
Overfilled?
Old Feb 20, 2008 | 04:29 PM
jeggy's Avatar
take a picture because your description can be quite confusing
Old Feb 20, 2008 | 04:31 PM
Apex_AP1's Avatar
how do I post pics on here?
Old Feb 20, 2008 | 04:41 PM
jeggy's Avatar
[img] copy and paste link to pic here [ /img]
Old Feb 20, 2008 | 05:19 PM
CoralDoc's Avatar
If the leak is betwen the red valve cover and the head, it's pretty normal. If that's the case, replacement of the valve cover gasket should do the trick. This doesn't usually become a problem until you have a good amount of miles on the engine, so how many do you have on your 8 year old car?
Old Feb 20, 2008 | 05:22 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
I'll bet he means where the head meets the block (chaincase leak)
Very common to find a light oil stain here.
Old Feb 20, 2008 | 05:44 PM
Apex_AP1's Avatar
I have only 66K miles, was hardly driven when I purchased it
Old Feb 20, 2008 | 06:05 PM
Apex_AP1's Avatar
yup!
