Wedssport TC105N
im about to drop the hammer on these wheels. ive read the wheel fitment guide and im sure these will fit but id like some input to be assured these will be ok without rolling or relocating etc... the specs are: front 17x8 +49 rear 17x9 +49
depending on the camber you're using front and rear, I would think you have to roll and relocate the bumber tab in the rear. Another variable to consider is the tire you're going to run front and rear, size-wise.
i have 17x9 +45 and when i had 245's in the rear i barely rubbed because i had a little bit of neg camber. So ur set is 4mm less so might be able to get away without rolling, u just got to mount them and see.
I'll pick up a pair sometime this summer I think.
