EMU Question, Converting Fuel Map
Old Nov 11, 2009 | 07:04 AM
jari8378's Avatar
Thumbs up EMU Question, Converting Fuel Map
I noticed that my current map(inj 1 and inj2) were tuned by using the stock map sensor voltage(not sure why my tuner neglected the greddy map). I would like to use the greddy sensor, however i do know from research that voltage/psi is not the same for both sensors.
Here are some of the equations i have found on S2ki, from mugenrios2k and dsddcd....
Stock Map Sensor
psi=5.395*volts-15.37
volts=(psi*15.37)/5.395
Greddy Map Sensor
psi=14.5*volts-21.75
volts=(psi+21.75)/14.5
My current plan is to make each column its own independent line(y=mx+b).. and figure out what the appropriate voltage would be for the greddy map sensor.
Does anyone else have a better method?
-thanks in advance
-Lu
Old Nov 11, 2009 | 07:11 AM
dsddcd's Avatar
How is this?
V Stock..........PSIG...................V Greddy
3...................0.8089....................1.55 6
3.25..............2.157725.................1.649
3.5...............3.50655................... 1.742
3.6...............4.04608................... 1.779
3.7...............4.58561................... 1.816
3.8...............5.12514................... 1.853
3.9...............5.66467................... 1.891
4..................6.2042..................... 1.928
4.1...............6.74373................... 1.965
4.2...............7.28326................... 2.002
4.3...............7.82279................... 2.040
4.4...............8.36232................... 2.077
4.5...............8.90185................... 2.114
4.7...............9.98091................... 2.188
4.8...............10.52044................. 2.226
5..................11.5995................... 2.300
Greddy V vs Press
V.....................PSIG
0.5..................-14.5
0.7..................-11.6
0.9..................-8.7
1.1..................-5.8
1.3..................-2.9
1.5..................0
1.7..................2.9
1.9..................5.8
2.1..................8.7
2.3..................11.6
2.5..................14.5
2.7..................17.4
2.9..................20.3
3.1..................23.2
3.3..................26.1
3.5..................29
Old Nov 11, 2009 | 07:15 AM
jari8378's Avatar
Originally Posted by dsddcd,Nov 11 2009, 08:11 AM
How is this?
V Stock PSI V Greddy
3 0.8089 1.556
3.25 2.157725 1.649
3.5 3.50655 1.742
3.6 4.04608 1.779
3.7 4.58561 1.816
3.8 5.12514 1.853
3.9 5.66467 1.891
4 6.2042 1.928
4.1 6.74373 1.965
4.2 7.28326 2.002
4.3 7.82279 2.040
4.4 8.36232 2.077
4.5 8.90185 2.114
4.7 9.98091 2.188
4.8 10.52044 2.226
5 11.5995 2.300
thats the same #'s i got.
the EMU will not let me use values like...
1.64....
they have to be in .05 increments...
Old Nov 11, 2009 | 07:27 AM
dsddcd's Avatar
You have to round to the closest number, you can always do it automaticlly with the =Round() function in Excel
Old Nov 11, 2009 | 07:52 AM
jari8378's Avatar
sooo...
this is what i would input?
Sotck volts PSIG.... V Greddy Input value
3.............. 0.8089...... 1.556....... 1.55
3.25......... 2.157725.. 1.649....... 1.65
3.5........... 3.50655.... 1.742....... 1.75
3.6........... 4.04608.... 1.779....... 1.75
3.7........... 4.58561.... 1.816....... 1.8
3.8........... 5.12514.... 1.853....... 1.5
3.9........... 5.66467.... 1.891....... 1.9
4.............. 6.2042...... 1.928....... 1.9
4.1........... 6.74373.... 1.965....... 1.95
4.2........... 7.28326.... 2.002....... 2
4.3........... 7.82279.... 2.04......... 2.05
4.4........... 8.36232.... 2.077....... 2.5
4.5........... 8.90185.... 2.114....... 2.1
4.7........... 9.98091.... 2.188....... 2.15
4.8........... 10.52044.. 2.226....... 2.2
5.............. 11.5995.... 2.3........... 2.25
this doesnt make sense to me as there will we 2 rows that will have duplicate values.
sorry to bother you. I just want to make sure i do this right.
BTW the tuner used the same stock voltage values.
Old Nov 11, 2009 | 09:04 AM
dsddcd's Avatar
At 3.7 volts Stock you should use 1.85 V Greddy
Notice you loose resolution with a larger span sensor, which is a downside that most don't understand.
Old Nov 11, 2009 | 09:10 AM
TRBOKEV's Avatar
I was just about to say that...
4 volts should also be 1.95
4.4 should be 2.10
4.7 should be 2.2
Luis who taught you math? LOL
Old Nov 11, 2009 | 09:12 AM
jari8378's Avatar
wasnt sure if i was suppose to round down or up
Old Nov 11, 2009 | 09:14 AM
jari8378's Avatar
3.7........... 4.58561.... 1.816....... 1.85
3.8........... 5.12514.... 1.853....... 1.85
4.............. 6.2042...... 1.928....... 1.95
4.4........... 8.36232.... 2.077....... 2.1
4.7........... 9.98091.... 2.188....... 2.2
So the duplicate values wont matter.... let me upload my map
Old Nov 11, 2009 | 09:26 AM
jari8378's Avatar
