Sponsored by:
Sponsored by: Sake Bomb
needing ball joints ASAP!
Old Jul 20, 2010 | 10:23 AM
marshman's Avatar
Default needing ball joints ASAP!
ok so although i was warned about it, i didn't "nut the bolt" when removing my rear knuckle. i disoriented the threads on the upper joint and the joint more towards the front of the car.
where can i locate the ball joints i need and what are the tools necessary to swap them out?
Old Jul 22, 2010 | 09:49 PM
brax_1's Avatar
I believe you need to buy the whole control arm. Honda doesn't sell the balljoints separately.
Old Jul 24, 2010 | 02:10 AM
lamwai's Avatar
I think hardrace selling the ball joints.
http://www.hardrace.com/products.asp...1&strClass2=31
REAR UPPER ARM BALL JOINT (OE SYLTE) 2PCS/SET (6996)
REAR LOWER ARM BALL JOINT (OE SYLTE) 2PCS/SET (6998)
Call them up.
You can rent the ball joint press and the removal kit from Autozone or Kragan for free but they required deposit. Then you don't need to bring it to the shop.
And I found some oem ball joint from ebay but I am not sure about the quality. If your car is not lower, don't get the lower ball joint.
If you damaged the tie rod, then you will need to get a new one from Honda.
I hope this help.
Old Jul 25, 2010 | 11:28 AM
marshman's Avatar
i damaged the threads on the ball joints on the tie rod and the upper. where does that leave me?
Old Feb 22, 2011 | 06:44 AM
McHeizer's Avatar
Call them up.
I hope this help.
Did you ever order there or know someone who did?
Experiences with their service?
How is the parts quality?
Thanks
TrumpetTitan
Apr 26, 2016 09:56 AM
mirabileboy
Sep 2, 2015 10:30 AM
Motoxer4life
Aug 5, 2010 07:19 PM
go hard jersey
Mar 26, 2010 04:12 PM
bpaspi
Oct 17, 2009 03:32 AM
