The Blackmarker's Project S2K Diary - Updated Feb24th, 2012
Old Nov 7, 2010 | 03:31 AM
lookinco's Avatar
Default The Blackmarker's Project S2K Diary - Updated Feb24th, 2012
** See Page 4 for most updated status and pictures - July 18th, 2011 **
With so many crazy S2K on this board, it's hard to standout and be unique. However I am still gonna do my best, and this will be the diary for the upcoming build up for The Blackmarker's Project S2K.
The goal is to build a daily drivable and trackable project car. I tried hard to find a balance in between both, and so far I have been quite happy with the outcome.
For those who remember, I had a project thread titled "Advance Motorsport 2009 Project Car " which showed how I turned my bone stock s2k into the way it is currently sitting now.
Current Mod List:
Engine setup:
JDM F20C OEM short block (Got it from AJR, they said they got it from Spoon)
Alaniz Ported and Polished F20C head:
Supertech Stainless Steel OEM size valves
Supertech Double Valve springs
Supertech Titanium Valve Retainers
ARP headstuds
Hondata Intake Manifold Gasket
F22C valve covers with 2006+ sensors (For Hondata Kpro)
NRG Engine Torque Damper with PuddyDad Mount
Krankvents
Engine Breathing:
J's Racing Titanium Header
Invidia 70mm Testpipe with O2 Fix
STOCK EXHAUST (I had 5 different single exhausts and they were all too loud for my local track. Will have a custom one for the next build)
Forced Induction, Fuel System, and Engine Tuning:
Kraftwerks Supercharger YouTune System with Rotrex C30 Supercharger
RC Engineering 750CC Saturated Fuel Injectors
Walbro 255lh High Flow Fuel Pump
Hondata K-pro Standalone ECU
Snow Performance Meth/Water injection cooling kit
MASE TUNED!!
Dynoed at 330whp, 240tq on a Mustang Dyno
Engine Cooling:
Samco coolant hose
Mugen Fan switch
Mugen Thermostat
Transmission / Clutch:
ACT Heavy Duty Pressure Plate
AP2Transmission
OEM AP1 Flywheel
OEM AP1 Clutch Disc
Foot Work:
KW Variant 3 Coilover Suspenion
Cusco Front Sway Bar
Cusco Front lower member tie bar
Cusco Rear lower member tie bar
Cusco Chassis Ladder bar
OEM AP1 Rear Sway Bar
J's Racing Front Roll Center Adjuster + camber kit
J's Racing Rear Roll Center Adjuster
AP2 Rear Subframe
Megan Racing rear toe arm (Rear Bump Steer Kit)
Megan Racing front tie bar endlinks (Front Bump Steer Kit)
T1R Half Shaft Spacers
Wheel/Tires/Brakes:
Enkei RPF1 F:17x9 +45mm, R:17x9 +35mm
Bridgestone RE01R F:225/40-17, R:255/35-17
949 Racing 6URL 17x9, 17x10 (Track)
Dunlop Starspec 245/265 (Track)
Carbotech XP10 brakepads (front)
Carbotech XP8 brakepads (rear)
Carbotech rotors
Custom Front Brake Ducts
Motul 5.1 Brake fluid
Electronics:
Clarion Headunit
Braille Carbon Battery (11lb)
Racelogic Traction Control system with Launch Control
Exterior / Aerodynamics:
J's Racing TypeS V1 Full Aero Kit (Front, Side Skirt, Rear bumper)
J's Racing TypeS Carbon Canards
J's Racing TypeS Carbon Brake Ducts
J's Racing TypeS Front Tow Hook
J�s Racing Carbon 3D Type1 GT Wing
ASM rear over fender (molded) (15mm wider)
Carbon front wide fender
Custom OEM Vented Hood
Custom Lamboghini White paintjob
LED DRL
Interior:
Custom wrapped Black Leather / Alcantara steering wheel
Custom Alcantara Shift Boot
Bride Brix II seats with Bride MO seat rails
Defi Boost Gauge
Defi EGT Gauge
Defi Fuel Pressure Gauge
AEM UEGO Wideband Gauge
Modifry Shift Beeper
Skunk2 Titanium Shift Knob
Black Leather Center Console Cover
Seatbelt Lock
And some current pictures:
http://www.youtube.com/watch?v=ZFeXV0lvDQI
http://www.youtube.com/watch?v=aSjjg3TKZLc
Old Nov 7, 2010 | 03:48 AM
lookinco's Avatar
So now you have seen how my car is like currently, now it's time for the next stage!
This is where The Speed Syndicate comes in.
They are a relatively new shop, but the skills and knowledge these guys have are AMAZING!! They do some of the best fab work I have ever seen. Pretty much you name anything, and they can make it. They will be doing some extensive fab work on The Blackmarker's Project S2K, as we will need it in order for our next Force Induction Plan to work.
Here are some pictures of their custom Top-Mount intercooler for the S55 AMG.
And a quick shot of the custom V-Mount they did on their Project STi
Old Nov 7, 2010 | 04:06 AM
lookinco's Avatar
So anyways, back to The Blackmarker's Project S2K.
For our next project, we are going to ditch the tiny C30 Rotrex Supercharger.
In goes the BIG BROTHER! The C38-91, Rotrex newest C38 series charger. We have no idea how much power it would make yet, as this will be one of the very first C38-91 to be installed in a S2K. For those who are not familiar with what the C38 can do, you can view the following video.
This video is a TTS Supercharger kit with the C38-81 (slightly smaller then C38-91), about 15psi on a bone stock F20C, reved up to 8500 (It started to detonate up top as it wasn't done tuning)
http://www.youtube.com/watch?v=Udqfy0D8abg
So yes, our next project will be the C38-91, along with a custom V-Mount setup. Richard from TTS has already shipped out the Charger, Bracket, and Pulley. Once we get them in our hands, the guys at The Speed Syndicate will start the fab work on the custom V-mount.
In the mean time, I gotta prep my engine for the higher boost that's coming my way.
We will be using a stock AP1 short block, rehone it to fit the 0.25os Mahle Pistons. The setup will be a 2.2L setup, with a teflon coated 2.2 Crank, Pauter 2.2L rods, and Mahle 9.5cr pistons. Of course we will also keep the Alaniz Ported and Polished head on it.
For the clutch, I chose to use the SOS Twin Disc Carbon Clutch. This clutch look so sexy just sitting on the table.
Some other parts includes Innovate engine mount, Evasive Diff Collars, Stainless Clutch Line, and some ID1000 injectors.
So on Monday I am sending the block out to get built. Hopefully in about a week the block will be ready and the charger will be here.
Will keep you guys updated! And sorry for the long ass thread.
Old Nov 7, 2010 | 05:42 AM
aDoG's Avatar
WOW!
Old Nov 7, 2010 | 06:34 AM
clarkster009's Avatar
WOW is right...that is a long list of parts! How long have you been working on your build before posting this? I think it looks good but I have never been a huge fan of the Js kit. Why did you go with 225s on the 9" RPF1 up front though?
Old Nov 7, 2010 | 07:31 AM
drewschindler's Avatar
nice build!!!!! hell of a parts list
Old Nov 7, 2010 | 08:21 AM
blixhavn's Avatar
sick built you got started... cant wait to see your results
Old Nov 7, 2010 | 08:35 AM
myclue's Avatar
Gold Member
this is a crazy build!! good luck with everything
Old Nov 7, 2010 | 08:38 AM
FTW.inc's Avatar
what did you spray the trunk with?
Old Nov 7, 2010 | 09:29 AM
s2sik's Avatar
