CASTRO's Services
So... here's a thread I'll start up that I'll be editing often as needed.
Basically, if you need misc maintenance work done, contact me with what you had in mind and I'll get back to you as soon as I can.
I'll match or beat almost any dealer/shop quotes in the area
Here's a copy/paste list of a few suggestions from the top of my head:
Mechanical:
-Valve Adjustment
-Valve gasket replacement
-Valve retainer inspection
-Clutch slave cylinder lubrication
-Shifter lubrication
-Shifter plastic parts inspection/replacement
-Oil Changes
-Transmission fluid
-Differential fluid
-Suspension parts
-Sway Bar/Strut Bar Installs/Adjustment
-Seat Lock installs
-Hard Top Lock Install
-Coilover adjustments
-Brake work
-Spark Plug check/replacements
-PCV valve replacement/cleaning
-Mod install (ex:Intake/Exhaust/etc)
-Throttle cable adjustment (lol)
-Replace cabin pollen filter
Audio/Interior:
-Head unit installation
-Modifry or similar accessories
-Modifry Shift Beeper Install
-Top down rolling mod
-LED Footwell illumination
-LED Maplight Installs
-Speaker replacement/installation
-Amp Wiring
-etc
Mechanical:
-Valve Adjustment
-Oil Changes
-Transmission fluid
-Differential fluid
-Suspension parts
-Seat Lock installs
-Brake work
Audio/Interior:
-Amp Wiring
-etc
Easy! Me and the mad scientist got to rip apart the block... and replace the piston rings you fried.
-The Diesel
You know what? This will decimate all, after, you put about fifteen grand in it or more. If we have to, overnight parts from Japan. -Jessie
Castro knows his stuff for sure I was very happy after our tech day! He was extremely helpful and I can deff vouch for him! My car is running top notch now!
Here's what I did:
-valve adjustment
-shifter lubrication
-clutch slave cylinder lubrication
-pcv valve change
-valve gasket change
Here's what I did:
-valve adjustment
-pcv valve change
