CEL: P0128 Coolant Thermostat
Old Oct 25, 2011 | 07:22 AM
MegaTRon's Avatar
Default CEL: P0128 Coolant Thermostat
I have MY06 with test pipe and flashpro. I got this CEL this morning going driving to school. How do I fix this issue?
coolant temperature below thermostat regulating temperature)
Old Oct 25, 2011 | 07:25 AM
Chief Robert's Avatar
I had that CEL code when I first bought my car and I had to change the thermostat. My car used to take a long time to warm up.
Old Oct 25, 2011 | 07:32 AM
MegaTRon's Avatar
strange. my car warm up to 7 bars which is normal and the code is still there. how much is it for a new thermostat? i dont feel any loss in power. should I just clear the cel?
Old Oct 27, 2011 | 11:27 AM
MegaTRon's Avatar
CEL only comes on the cold mornings. My car warms up fine like it normally does. Should I still replace the thermostat?? or could it be something else? I dont want to spend 50.00 and it ends up not being the problem.
someone chime in please. billman where you brother??? lol
Old Oct 27, 2011 | 12:54 PM
S2K-F8's Avatar
8 bars is normal for an AP2. Are you running an aftermarket thermostat (lower temp)?
Old Oct 27, 2011 | 01:53 PM
MegaTRon's Avatar
only mods are test pipe and flashpro. everything is stock. currently getting my car etune and its running stronger than ever.
Old Oct 27, 2011 | 04:00 PM
zeroptzero's Avatar
I just had that code and it was my thermostat stuck open, but my car would not warm up properly, so it was a sure bet for me. My thermostat had a piece of metal lodged in it from my aftermarket radiator, I wouldn't expect that to happen to many others out there though. If your car warms up properly I'd clear it and see if it returns.
Old Oct 28, 2011 | 01:01 PM
Rdizzle's Avatar
If your thermostat is stock, then that code means that it's a bad thermostat (probably stuck open). May not be a bad thing if you live in a warm climate or if you track your car as your engine will be kept cooler. This issue won't impact performance of your car.
Old Oct 29, 2011 | 05:50 AM
Spanky's Avatar
I've been through the same code a few times. I have a Koyo radiator, Spoon thermostat (which I hear opens at much cooler temps), switch, and an aftermarket intake manifold gasket. I've learned that if I take it above 4000rpm without letting the engine warm up to the normal operating temperature (3 bars on an AP1) it will trigger that code. Give yourself some time to warm up the motor and take it easy for the first couple miles before getting on it more. Just stay below 4k rpms until you see the normal amount of bars on your temp gauge (Idk what it is for AP2's, 8 bars?) Mine takes forever to warm up and I live in Hawaii! Good luck!
Old Oct 29, 2011 | 10:11 AM
japhethwar's Avatar
The car is looking to achieve a certain temp in a set amount of time based on a variety of parameters, Air temp, load, etc. Almost always is a thermostat with a weak spring opening a little too quickly for the computers taste. Very common code on a variety of cars. Have seen this code triggered buy a very dirty air filter causing scewed air temp readings a time or two as well. Check the car over, filter clean, coolant full, etc. If no issues def. gonna be a faulty thermostat about 95 out of 100 times. BTW normal operating temp for 06+ is 8 bars on the guage.
