Autoleads Manual Info Requested
Old Nov 11, 2011 | 11:22 AM
loftust's Avatar
Default Autoleads Manual Info Requested
After I disconnected my battery last weekend, the only part of the audio controls on the dash that works is the mute light (shocker!).
I ditched the instructions when I fitted the patch lead (PCX-99??? for Alpine HU), and wondered if someone could post the procedure for syncing the patch lead to the HU. IIRC, it involves disconnecting the patch lead and reconnecting, then turning on the HU in a certain order.
If anyone can help, I'd be much obliged
I know this method will work if done correctly as I had to undertake it many times prior to all the buttons working
Old Nov 13, 2011 | 01:58 AM
veehexx's Avatar
well, i recently fitted the device, without instructions, heres what i did:
keys out of the ignition, plug in everything apart from the REMOTE wire to HU (i actually forgot about the REMOTE wire)
power it on as normal.
turn HU off, plug in REMOTE wire
turn HU back on and things just worked for me.
mine is autoleads + pioneer HU.
hth
Old Jun 22, 2012 | 03:24 AM
jcoa's Avatar
I have the same problem because of disconnecting the battery and my sterring audio controls wont work.
I tried your way to do it and still it wont work.
First time when i installed my autoleads i just connect everything and it worked. It wont work anymore.
When u installed it did u wait for some time to connect the wire to the HU? Or maybe engine was running?
Maybe i did the sequence wrong.
Please help
Old Jun 22, 2012 | 04:59 AM
hazzaman's Avatar
Loftust - I had the same issue. It was a radio out job and a case of unplugging the power to the little black box, leaving for a few mins and reconnecting. Think i ended up doing this 3 or 4 times between powering the radio on and off and it started working eventually.
IIRC, I also had the same issue installing it, but once it's working it tends to stay working!
Old Jun 22, 2012 | 06:09 AM
kim-s2k's Avatar
I hate that autoleads harness with a passion.
No wiring is worth sitting in the car for hours trying to get it to work.
Old Jun 24, 2012 | 10:25 PM
jcoa's Avatar
Chris can you tell me how you do it in sequence?
Old Jun 25, 2012 | 03:21 AM
FastFez's Avatar
I found this on the net http://www.nexxia.co.uk/PDF_Files/PC99-KEN-DIS.pdf Its for a Kenwood but I'd imagine the sequence is much the same...
Old Jul 17, 2012 | 08:05 AM
jcoa's Avatar
i did the sequence many many times but still it wont work
is there any other way? somebody please help
Old Nov 3, 2013 | 10:32 PM
Kingkirk001's Avatar
I am currently having the same problem at the minuets and I have a alpine hu aswell,
I did the same just pluged it in an turned it on but no joy, so I tryed the sequence over and over and still no joy
Any ideas?
Old Nov 4, 2013 | 04:29 AM
2HondaDave's Avatar
Any ideas?
I am about to do this so have no actual experience of what works and what doesn't... but I read the instructions the other day and it said "for Alpine head units you may have to do this several times before it works"... this has not filled me with joy.
I don't have the instructions with me or I'd type it out for you, it wasn't exactly comprehensive.
