New York - Metro New York S2000 Owners Owners in New York City, Long Island, New Jersey, Connecticut
2-Way Differential Daily Driveable?
Old Feb 11, 2012 | 12:42 PM
ipopvtec's Avatar
Default 2-Way Differential Daily Driveable?
Hi Guys,
I have been debating getting this Drexler LSD with my tax return money for a while now. From what I read it is very quiet while loading and unloading and runs flawlessly even in the rain. (Please don't explain to me why OSG is better and cheaper, I am set on the Drexler.) ASM/GoTuning sells this LSD for $6300, but I found that if I get the same specs as ASM from Drexler direct I can get the unit for a little less than $2500. I am probably going to get a ramp angle combo of 45/45.
I have searched the fourm and I havent came across anyone actually running this LSD. I wonder why? I also wanna make sure I know why the ASM one is $6300, and from Drexler direct its half that. (I know ASM RAPES people on prices so I believe it.. but just want to make sure.)
Also, do any of you guys run a 2way diff on the street? Is it safe as long as your not a noob (i.e. lifting throttle mid turn)? Also wondering why NO car comes stock with one?
Please let me know.
http://www.gotuning.com/product_info...roducts_id=945
Old Feb 11, 2012 | 12:45 PM
iLuveketchup's Avatar
What are you trying to fix or accomplish with a 2-way LSD?
Old Feb 11, 2012 | 01:04 PM
ipopvtec's Avatar
Not a big fan of the stock torsen. I would like to have more stable turn in, and mainly better control of my tail end.
I also want it because I like to have a little fun with the rear end on the street, but want something serious at the same time for the track/autocross. This is my weekend car, not my DD, but I still drive about 2-5,000 miles a year on the street.
Old Feb 14, 2012 | 12:39 AM
wrecked's Avatar
ive noticed sometimes when i want to slide the rear out a little, when im making a 90 degree turn at low speeds and hit the gas, the inside wheel spins a little and then it grabs finally. I think something might be wrong with the diff.. I believe I'm running the recommended fluid made by redline. is this normal?
Old Feb 14, 2012 | 06:03 AM
ipopvtec's Avatar
What kinda diff do you have?
Old Feb 14, 2012 | 11:19 AM
wrecked's Avatar
OEM as far as I know. lol
Old Feb 14, 2012 | 02:29 PM
ipopvtec's Avatar
Shouldnt be spinning under accelleration. Ask billman, he is s2k god
Old Feb 14, 2012 | 07:30 PM
bbp's Avatar
bbp
it is limited slip and this is how it works
Old Feb 14, 2012 | 07:45 PM
bbp's Avatar
bbp
2-way LSD???
it will make you slide all over when you are turning fast (on and off throttle) and when you will be making U-turns your car will be hopping like a bunny.
If you really want a 2-way LSD I suggest welding the stock diff. 2-way or welded diffs are used for drifting or drag and most likely will make you slower on a road course.
Old Feb 14, 2012 | 08:48 PM
ipopvtec's Avatar
Originally Posted by bbp
Originally Posted by ipopvtec' timestamp='1328997874' post='21405788
[quote name='iLuveketchup' timestamp='1328996725' post='21405748']
2-way LSD???
[/quote]
Thanks for the info. Just curious.. how come the ASM s2000 laps tskuba in under a minute with a 2 way LSD? I understand an agressive ramp angle combo will make you spin intensively.. but even 45/45 or say 50on/40off setup?
Essentially does it not just limit the slip rather than cut out slip completely?
