Motor mounts
Old Aug 14, 2012 | 02:47 PM
  #21
sata3000's Avatar
Originally Posted by spectacle
Figure out why they're breaking first, then proceed from there.
If you blew a motor, wouldn't you want to know why it blew first before you replaced it?
what reasons do you believe would cause a mount to break?
Sent from my Galaxy S II using Tapatalk
Old Aug 14, 2012 | 05:51 PM
  #22
Spoolin's Avatar
I have yet to break a stock mount and I'm making 800 whp on same mounts the car came with in 02. 16k miles later and no problems. Although I don't dig race the car and that, along with other abuse I believe is what causes the broken mounts. Why not just look into a torque stabilizer to just limit hard hits to the mounts with engine torquing and limit engine movement? the stabilizers work like a suspension shock.
Old Aug 14, 2012 | 06:29 PM
  #23
passmans2kny's Avatar
Aftermarket mounts are like 3mm headgaskets...everyone thinks they need them until they realize, they don't.
i need that kinda stuff today
Old Aug 14, 2012 | 07:26 PM
  #24
spectacle's Avatar
Originally Posted by herecomesboost
spectacle, not that I necessarily disagree with your assertion that street cars should stick to stock mounts, but the engine most certainly moves laterally. As a quick example, pop the hood and watch your engine as your start/stop the car; then engine will shift (if you're running stock mounts).
Agreed. I never said the motor doesn't move. But in our application, that doesn't matter.
Abuse. Same reason stock diffs and trannies break. You can drive a high hp s2k on the street without breaking the drivetrain, but you can't abuse it like you would a built one.
Let's put it this way. There are people on this forum that have broken the stock diff with stock power and called it "weak". Relatively speaking to other options, yes it is...but they never fess up to what they were doing when the diff popped. They're doing 8k clutch drops on street tires and wondering why shits breaking! Anything will break with abuse...v160's, 8.8 diffs...when it comes to stuff like that, why be concerned about the motor moving a little bit? All that vibrations gotta go somewhere...
All I'm trying to do is steer people away from another useless mod. These mounts are becoming the new 3mm HG
Old Aug 14, 2012 | 09:54 PM
  #25
Corey Maurer's Avatar
I plan on making solid aluminum mounts out of my innovatives, Ill let you guys know how much they suck
Old Aug 15, 2012 | 05:05 AM
  #26
AusS2000's Avatar
Stick with OEM.
Did somebody mention head gaskets?
Old Aug 27, 2012 | 08:38 AM
  #27
Excalibur's Avatar
Where is the best deal on hasport 70a motor mounts?
Old Aug 27, 2012 | 08:46 AM
  #28
herecomesboost's Avatar
I bought my through Evasive
Old Aug 27, 2012 | 08:56 AM
  #29
Mivec's Avatar
Motor mounts aren't pointless, they improve motor response and torque
Old Aug 27, 2012 | 09:05 AM
  #30
camuman's Avatar
did you copy and paste that from the description of a site selling them? on some cars, they are great. i remember my jetta had shit ass stock squishy mounts. popped in the stiffer ones, motor stopped flopping around, vibration was minimal to non existent. i did them to stop the motor from smacking the fire wall. if you think you are going to see a percievable difference in motor response and tq then you are on some good shit my friend and i want some.
the only thing that comes of motor mounts on an s2k is sweet sweet vibrations that are felt throughout the cabin. the stiffer the mounts, the quicker your girlfriend gets off in the passenger seat.
