Sponsored by:
Sponsored by: Sake Bomb
OEM or custom alignment
Old Sep 22, 2012 | 02:03 AM
03suzuka...s2000's Avatar
Default OEM or custom alignment
So I have been wanting to get new tires and an alignment. Its my daily driver but want a somewhat ag gressive alignment thats not gunna eat thrumy tires much more than OEM. Im wanting to go with a little more camber so I can fit 255's in the rear. I might go with a re-barel on my front wheels so the fronts will be 17x9.5 +55 to match the rear. Or is that too aggressive in the front? My car already has a basic roll/ no pull all around.with the bumper tab relocated
But for now my setup is 17x8 +43 w/225/45- 17x9.5 +55. W/245/40 lowered so there is about 1 finger gap between tire and wheel well
What would be a good alignment for this? Because my car seems to be a little dull while handling compared to when I first got it.and compared to my friends S2000. When I first got my car I got a bit of oversteer compared to the pretty bad understeer im getting now
Old Sep 22, 2012 | 05:35 PM
Nobody has there own alignment specs they like for the s?
Old Sep 22, 2012 | 10:15 PM
MMisencik157's Avatar
I would go -1.5 camber all around, 0 toe front and rear... or up to 1/16" toe in in the rear (save your tires), and max caster.
Old Sep 23, 2012 | 03:37 PM
What would max caster do?
Old Sep 23, 2012 | 05:03 PM
helps out with stability
Old Sep 23, 2012 | 10:46 PM
RaulChavez's Avatar
I have -1.5 camber up front with zero toe. In rear I have -2.5 camber with .2 toe in each side.
If your worry about tire life I say stay with -1.5 camber like said above and stay below .1 toe in rear.
Old Sep 24, 2012 | 05:13 AM
RedCelica's Avatar
-1.8f -2.0r
0 toe f .15 total toe r
max caster
I love my specs, car rotates and tires wear evenly
Old Sep 24, 2012 | 10:34 AM
Croc's Avatar
anyway - don't do zero rear toe - it's good for drifting not for stability.
Old Sep 24, 2012 | 01:39 PM
Hes not talking about tracking the car so why not get a little more tire life? You would never notice the difference when driving on the street or highway.
Old Sep 24, 2012 | 01:45 PM
Croc's Avatar
you don't need to be at rack to do fast turns.
too risky IMOand no no for the non expert driving.
