Automotive builds Got an automotive build you want to want to document? Post it here!
Lord09's Log
Old 10-10-2013, 09:09 PM
Lord09's Avatar
Default Lord09's Log
This will probably be a fairly boring thread, but I plan to keep a log of everything I do to my 2003 Silverstone, mostly maintenance and minor mods.
To be updated soon.
10/14/2013 - 93136: Driver Door Checker / Detent Rod / Door Check Strap Replacement
10/15/2013 - 93161: Addressing Sticky / Overly Firm / Squeaky Clutch
10/15/2013 - 93161: Skunk2 Shift Knob + twist Shift Boot Adapter
10/17/2013 - 93234: Cabin Filter Replacement
10/17/2013 - 93234: Modifry Straps
10/19/2013 - 93276: Serpentine Belt + Air Filter
10/19/2013 - 93276: Convex Moddiction Side Mirrors + Spoon Rear View Mirror
10/21/2013 - 93353: Slightly Squeaky Top
10/24/2013 - 93422: Berk 63.5mm HFC
10/25/2013 - 93456: Steering Wheel Squeak Fix
10/28/2013 - 93500: UK Alignment Specs
10/28/2013 - 93500: Dyno!
10/28/2013 - 93500: Rick's Luxury Mats
11/01/2013 - 93543: Audio Upgrade!
11/16/2013 - 94368: OEM AP1 Lip
11/21/2013 - 94524: UK Exhaust Mod
11/27/2013 - 94669: PCV valve / Updated MAP holder / Door stabilizer clip
Old 10-10-2013, 09:11 PM
Lord09's Avatar
Reserved.
Old 10-10-2013, 09:12 PM
Lord09's Avatar
Reserved.
Old 10-10-2013, 09:13 PM
Lord09's Avatar
Reserved.
Lord09's Avatar
Reserved.
Old 10-10-2013, 09:15 PM
Lord09's Avatar
Reserved.
Old 10-15-2013, 09:31 AM
Lord09's Avatar
I've had this clicking sound every time I opened the driver side since I purchased the car. Not only was it extremely annoying, it made the car feel cheap and flimsy every time I opened the car. It really diminished my impression of the car's overall build quality.
http://www.youtube.com/watch?v=4sVMvoqMh2k
Surprisingly this doesn't seem to be a very common occurence and I found very little information in my searches. I wasn't even sure of what this particular part was called. I did find the two following threads, which were helpful:
http://www.extremeprelude.com/doorstrap.html
https://www.s2ki.com/s2000/topic/279...#entry17057258
According to the WSM it's called a detent rod, the official part numbers call it a door checker, another site calls it a door check strap.
Part #s:
Driver side: 72380-S30-003 - Honda CHECKER, L. DOOR
Passenger side: 72340-S30-003 - Honda CHECKER, R. DOOR
Installation is very simple. First remove the door panel ( https://www.s2ki.com/s2000/topic/483...nent-speakers/ ), then remove the front speaker. Remove 2 10mm bolts holding the checker to the front door and then 1 12mm bolt on the front fender. Reach in and remove the old checker.
Installation is the exact opposite. The WSM didn't publish any torque specs that I could see, so I just tightened them until they were snug.
Extremely happy now.
Old vs. New:
Old 10-15-2013, 09:22 PM
Lord09's Avatar
My clutch has been quite sticky near the bottom of the travel of the pedal, extremely firm and squeaks occasionally especially when cold. Found this thread a week or two back: https://www.s2ki.com/s2000/topic/370...-clutch-pedal/
Read through the entire thread and found some more detailed steps (https://www.s2ki.com/s2000/topic/370...#entry20952445) and to be careful not to let the piston come out after removing the rod to clean up. If it comes out and you lose any fluid, you'll have to bleed the system. I used a zip-tie to hold the piston in place, worked great.
After removing the rod and rubber boot, I was shocked at the thick, slugdy grease. No wonder it was so sticky and required so much effort. After cleaning up the ball end of the rod with some coarse and fine sand paper, I liberally greased everything with Honda high temp urea. Also all the rubber boots were fully intact and in excellent shape so no need for replacement. I also used a thin paint brush and carefully ( or at least the best I could do given the tiny space and crawling under the car ) put grease on the tips of the release fork and spindle in the fork.
Put everything back together and what a difference. The clutch pedal is now sticky free and the movement is buttery smooth. The amount of effort is significantly reduced, the action is firm but extremely light. All squeaks are gone as well.
Driving is much more enjoyable now and the clutch feels like a brand new car, so smooth, never experienced a smoother better feeling clutch pedal.
Random notes:
Torque for the two 12mm bolts that hold the slave cylinder: 16 ft/lbs
Honda high temp urea grease part #: 08798-9002
Old 10-15-2013, 09:35 PM
Lord09's Avatar
Skunk2 Shift Knob + twist Shift Boot Adapter from k-series parts:
Love the knob, but hated how the top of the boot just kinda flopped around. Found this interesting adapter from k series parts and decided to order one to try out. A bit overpriced I feel at $15, but honestly looks and works great. Was just a bit narrow, but I wrapped the soft end of some velcro strips with an adhesive backing on the bottom of the adapter it holds and tensions the top of the boot perfectly.
I think it looks much cleaner and more importantly keeps the shift boot away from my hand, which I hate the feeling of when I drive.
I'm happy with the overall combination.
EDIT: The adapter rattled on the shift lever and there was as tiny bit of play, which I believe was causing it. Took some more of the soft velcro with adhesive on the back and carefully stuck it inside the adapter where it comes into contact with the lever. No more rattling!
Adapter: http://www.kseriesparts.com/cr/CLU1-08999-BAK-200.html
Shift Knob: http://www.amazon.com/Skunk-62799008...nk2+shift+knob
Old 10-15-2013, 10:34 PM
s1mba's Avatar
great thread so far, love the info you're posting
Quick Reply: Lord09's Log
