Mykeee's J's Racing Build
#21
compress the suspension to ensure you clear. that's what i had my body do. had him cut, roll and glass any sharp edges.
see bumper relocation tab: https://www.s2ki.com/s2000/topic/683...ar-bumper-tab/
can't wait to see thse on!
#22
You can use these instead of getting extended studs so that way you dont have to replace your wheel bearings when you do it. They bolt right on
http://www.evasivemotorsports.com/mm...s_Wheel_Spacer
If you run 25mm you also dont have to cut your oem studs and it allows you to completely reverse it in case you run a different wheel set up in the future
a 25mm spacer will put ya at 10'' +20 which is within a couple mm of what I'm running at a 9.5 +15mm with a 275 so it'll definitely fit!
#30
