675r vs. 848
Old 10-13-2014, 09:53 PM
Gotpepsi's Avatar
Default 675r vs. 848
https://www.youtube.com/watch?v=xe1FQrOWg18
I was watching this video and they mentioned the quick shifter a couple of times. Does this means that bikes are beginning to be clutch less now? I don't understand??
Old 10-14-2014, 02:27 PM
deception9's Avatar
some OEMs are equipping bikes from the factory with quick shifters. BMW's S1000RR is one that comes to mind. its really meant for all out acceleration.
that being said, most sport bikes with cassette transmissions can be clutchless upshifted. just roll off throttle sharply, press the shifter to desired gear and roll back on. its typically not recommended for down shifting
Old 10-14-2014, 02:47 PM
charlox5's Avatar
Like deception says, bikes have always been able to upshift without the clutch (downshift too, without grinding, though the engine braking always makes that less-than-fun). Bikes use a constant mesh transmission.
Quickshifters are basically software to cut fuel even with the throttle rolled WOT to allow a shift to take place then allow the bike to be at WOT once the shift is completed. All it's basically doing is removing the need to manually roll off throttle to upshift.
Old 10-15-2014, 12:04 PM
Gotpepsi's Avatar
Even if they can upshift without the clutch, do these bikes still have clutches?
Old 10-15-2014, 02:50 PM
deception9's Avatar
without exception, yes.
they always have a clutch.
Old 10-15-2014, 08:31 PM
Gotpepsi's Avatar
Why would you need a clutch if you can upshift without problem and down shift?
Old 10-17-2014, 08:45 AM
charlox5's Avatar
how are you going to get out of first with no clutch?
Old 10-21-2014, 01:37 PM
s2000Junky's Avatar
You ever jam a bike into first gear from a stop by mistake? Yeah ouch lol
Old 11-03-2014, 06:12 PM
Chris S's Avatar
i have a Triumph Street Triple R (kind of like a naked Daytona) w/ the quick shifter. It's really cool, you can upshift @ full throttle no clutch, no letting off the gas. If's more than SW, when you nudge the shifter if actuates the rest of the shift while slightly retarding the timing. Is it necessary for street riding? not at all Is it fun as shit? Hell yeah!
It def. shifts a lot faster than I can.
Old 11-05-2014, 11:13 AM
Suzuka_Joe's Avatar
the new 2015 s1000rr has a quick shifter for upshifting AND downshifting apparently. its gonna be badass
Quick Reply: 675r vs. 848
