| Welcome Guest ( Log In | Register ) | Resend Validation Email |
| Pages: (14) [1] 2 3 ... Last » ( Go to first unread post ) |
Silver9k |
Posted: Aug 21 2004, 11:06 AM
Guest S2KI User #: 35333 S2KI Age: 6 yrs 111 days PPD Average: 1.2 Owner 2007 GrandPrix White/Black-Red San Luis Obispo, CA ![]() |
Ok...I got this tip from some of the local car enthusiasts...and this is one cheap O2 simulator.
It works, and there is no need to cut any wires or anything...very easy as well. I personally have driven about 300 miles since, no CEL. So anybody who wants to run a test pipe...here is the mod you should do to stop the CEL...don't bother with the electronic ones with only some of them working...and not working all the time. These pics are from it being done STi, but I did it on my S, works just the same. ![]() ![]() ![]() or ![]() Those are the Spark plug, Anti-Foulers you'll need to do this..just pick them up at any auto parts store This post has been edited by SLO-S2000 on Aug 21 2004, 11:11 AM -------------------- ![]() 00 S2k 6/7/2004 - 1/31/2008 05 MCS 1/22/08 - 6/1/2010 07 GPW S2k 5/28/2010 - :)
Nobody |
Posted: Aug 21 2004, 01:37 PM
Guest S2KI User #: 4500 S2KI Age: 9 yrs 14 days PPD Average: 0.9 Owner 2002 Berlina Black/Race Stripped Bay Area ![]() |
Killer. Which part number did you use (there are two above)?
-------------------- 2006 ARC Race Series Champion (GT1) 2006 NCRC TT Series, 1st Place (GT1) My S2000 Racing Videos '02 S2000 * '06 Triumph Daytona 675 * '07 FJ Cruiser |
l8brakr |
Posted: Aug 21 2004, 01:39 PM
Guest S2KI User #: 31933 S2KI Age: 6 yrs 243 days PPD Average: 0.7 Owner 2003 Sebring Silver/Red Ph-Ph-Ph-Phoenix ![]() |
Umm, I don't get it?
This post has been edited by l8brakr on Aug 21 2004, 01:39 PM --------------------
Sub-Zero |
Posted: Aug 21 2004, 01:43 PM
Member![]() S2KI User #: 17197 S2KI Age: 7 yrs 287 days PPD Average: 2.4 Owner 2001 Berlina Black/Black Wesley Chapel ![]() |
-------------------- Sold swamp buggy! Projects in the works! 95 Targa Supra Turbo 73 GT2000 Let the autocross begin! 62 250GTO Ferrari kit car with LS1. Never to be finished All are for sale!!!!!!!!!!!!!!!!!!!!!! for the right price. ![]()
Slows2k |
Posted: Aug 21 2004, 02:27 PM
Site Moderator![]() S2KI User #: 13878 S2KI Age: 8 yrs 1 days PPD Average: 10.4 Owner 2002 Spa/Indy Yellow/Black ![]() |
I would give a little more time before claiming this to work. The codes for a Catalyst failure take some time before they are stored. The WRX pictured has a Convertor, weather or not it functions I don't know. I'm a little skeptical of this tricking the PCM simply by moving the 02 farther out of the exhaust flow.
-------------------- Whoretech'd twice ;) R.I.P. JS. ![]() ![]() ![]() ![]()
Silver9k |
Posted: Aug 21 2004, 04:10 PM
I'll let you guys know...this is actually something Evo guys are doing as well...
The STi, in the pic is a guy I know named Matt...its a high-flow cat in the picture. He has had this done for 3000+ miles, and yes, a high flow cat will set off the CEL in their cars (says him). What this does, is it stops the O2 sensor from seeing as much exhaust...nm, here's this... Pulled from Evolutionm.net Quote: I don't think this has been mentioned in the Evoutionm forums yet, but I've had a lot of success with a "mechanical" method that basically only allows the 2nd O2 to see a very small amount of exhaust gas, which it in turn translates this as a working cat. Therefore not tripping the CEL even with a cat bypass. I'm not sure how some of the vendors who sell pipes with guarantees do it, but I'd imagine it is something similar. Before installing this, my car used to set off the CEL on the 2nd key cycle after a few miles on the highway. After the installation of this piece, I havn't had a CEL yet. This included a 2500 mile drive down to California for 3 straight track days. Here's how it to do it: 1) Buy a set of 18mm Spark Plug Anti Foul Adaptors from the autoparts store. I got my from Schucks/Kragen/Checker and it came in a pair in the little red "Help" packages. These things are designed for cars that are burning oil and fouling it's plugs. 2) Drill out the small hole of one of the plugs to 1/2" diameter. This will allow the O2 sensor to screw into the plug while a tiny bit of room surrounding the sensor. 3) Screw either 1 or both adaptors together into the 2nd O2 bug on the cat back. Carefully screw the O2 sensor in. Don't overtighten since the adaptors are now pretty thin walled due to the 1/2" drilling. 4) Reset ECU by pulling the 2 ECU fuses in the fuse box under the hood (20amp and 15amp). ![]() The only reason you'd need to reset your ECU though, is if you currently had the CEL on. And there's a pic of one with a test-pipe for all you sceptical guys. Anyway...I'll keep you updated on the my CEL...if you want, I could take a pic of my test-pipe with this done...but it really looks no different. Anyway, I have driven from San Luis Obispo to Famoso raceway, done 4 passes, then back to San Luis with this...total of about 300 miles, if not slightly more...and probably starting the car up more then 10 times. I would assume the CEL would have gone off by now if it was going to? But like I said...I'll let you guys know. ohh and I personally used 42002...but it doesn't matter This post has been edited by SLO-S2000 on Aug 21 2004, 04:12 PM |
Silver9k |
Posted: Aug 21 2004, 10:10 PM
From Matt (guy that gave us these great pics The reason a high flow cat on the STi will STILL throw a P0420(cat inefficiency) code is because the factory exhaust system on the STi comes with TWO cats after the turbo...so basically my STi is essentially running with one less cat then what came on the factory exhaust which is the reason why it still is at risk of throwing a CEL with one high flow cat. Some STi's are fine with one high flow cat, some will still throw a CEL with one high flow cat...it's really case by case. In my case, the high flow cat on my STi still threw a P0420 CEL. There you go... Also, I drove the car more today...probably another 30miles and 4 starts...no CEL. I'm just trying to help you guys save some money and not have to cut wires... |
sportyking |
Posted: Aug 23 2004, 04:38 PM
Guest S2KI User #: 30090 S2KI Age: 6 yrs 336 days PPD Average: 0.2 Enthusiast Saarf London ![]() |
Slo,
Top suggestion, no sceptics here, I even understand the theory as the ECU looks for the second sensor to replicate the primary sensor readings but with slower fluctuations. I will give it a go as my CEL is a constant worry. I have never seen the Anti-foulers in the Uk, so any suggestions of a web based US supplier would be greatly apprciated.
Silver9k |
Posted: Aug 23 2004, 05:51 PM
Well, they cost about 4 bucks...how much would it be for me to ship it to you?
I'll do a quick UPS...ok NM...I did a check on a shipment to West Drayton (have a business card of an Indian Restaurant there)...51 buck...forget that...unless you really wanted to |
sportyking |
Posted: Aug 23 2004, 06:20 PM
Many thanks for the help so far Slo. You have PM.
The UPS option is way to steep, on principal but I am looking at options. |
Silver9k |
Posted: Aug 23 2004, 10:02 PM
Another picture to show the 1/2" part drilled. The actual O2 sensor probe just clears the 1/2" drilled hole...maybe 1/16" or 1-1.5mm on either side of it, so the limited space around the sensor also plays some part in it getting "fooled".
It looks like no space in the picture, but trust me...with 1/2" drilled...there is some space ![]() |
sportyking |
Posted: Aug 24 2004, 04:40 PM
Slo,
After complete failure trying to source in UK, Midway (US) have offered to post some to me, they worked the UPS shipping out to roughly the same figures you were given. Hope it works, either way I will let you know. |
gsp |
Posted: Aug 30 2004, 03:12 PM
Guest S2KI User #: 26684 S2KI Age: 7 yrs 55 days PPD Average: 0.2 Owner 2003 New Formula Red/Black ![]() |
Anyone tried this on an S2K?
Silver9k |
Posted: Aug 30 2004, 03:32 PM
I did...and I've gone over 2500 miles so far...and no CEL
sportyking |
Posted: Sep 1 2004, 09:08 AM
Slo,
parts arrived from Midway an hour ago, excellent service. Have drilled them out and hope to fit later, will let you know if I have the same success as you. |
sportyking |
Posted: Sep 1 2004, 12:14 PM
It Works!! It works!!
Fitted it Gave the car plenty of right foot treatment for about 75 miles including some WOT in lower gears. More than enough to get the CEL without the mod. Top tip Slo |
Silver9k |
Posted: Sep 1 2004, 12:22 PM
thanx man...hopefully more people will use this...its the best...IMO
NO wire cutting, SIMPLE, and EASY to turn back to stock... I'm really happy you had the same success |
dragonacc |
Posted: Sep 1 2004, 02:31 PM
Guest S2KI User #: 24006 S2KI Age: 7 yrs 111 days PPD Average: 0.1 Owner 2000 Atl ![]() |
Sweet, I don't even have an S2k and I'm going to be trying this. I knew I looked at this board for a reason. ;-)
AJ PwR |
Posted: Sep 1 2004, 03:33 PM
AJ Racing![]() S2KI User #: 1326 S2KI Age: 9 yrs 205 days PPD Average: 0.6 Owner 2003 GrandPrix White/Blue Tsukuba ![]() |
The way will definitely work
-------------------- ---------------------------------------------------------------------- A&J Racing International / Type One Racing International TEL: (604)279-0329 Email : ben@aj-racing.com AIM : AJR stock man MSN: ajrbun@hotmail.com **2007 Super Lap Battle Limited FR Champion 1:54.888** ![]() |
s2kboy03 |
Posted: Sep 2 2004, 04:10 AM
Guest S2KI User #: 36328 S2KI Age: 6 yrs 72 days PPD Average: 0.3 Owner 2003 GrandPrix White/Blue Calgary, AB ![]() |
for some reason i also running a t1r exhaust with testpipe just installed last week and so far no CEL goin on..been about 500 km so far...i dunno if i am lucky or not..maybe some cars just don't go off...dunno
This post has been edited by s2kboy03 on Sep 2 2004, 04:10 AM -------------------- 2003 Honda s2000 gpw/blue 223whp NA 1160kg(Sold 07/2007) Current Vehicle: 2008 Lexus IS-F Obsidian Black/Black |
markS2kcU |
Posted: Sep 5 2004, 10:51 AM
Guest S2KI User #: 35278 S2KI Age: 6 yrs 113 days PPD Average: 1 Owner 2002 Suzuka/Nurburgring Blue/Custom Suffolk ![]() |
Thanks to sportyking for parting with his spare set of non-foulers, I am now running this mod with my T1R test pipe, I have only done about 10 miles since fitting it but no CEL yet.
Got to love that sound now when hitting Vtec with the Mugen exhaust Thanks guys Ps. got a photo install if anyone needs it. -------------------- . FS: OEM High level spoiler. FS: BDL fuelrail, Spoon Hoses. FS: BBS JDM six spoke wheels, fronts only. .
TooBlue |
Posted: Sep 5 2004, 08:39 PM
Guest S2KI User #: 35488 S2KI Age: 6 yrs 105 days PPD Average: 0 Owner 2002 Suzuka/Nurburgring Blue/Blue Bel Air ![]() |
Installed it on my S2K this weekend, 60 miles total, 4 on/off cycles, no CEL. Prior to this CEL kicked on 2nd cycle
An excellent tip. How it works is kind of a mystery though. Maybe the O2 heater burns up some of the remaining combustibles in the small chamber that is created, and drives the differential in O2 presence the ECU is looking for. No matter how it works, it does the job. Thanks so much! |
Silver9k |
Posted: Sep 6 2004, 11:27 AM
ok, quick question for everybody that has tried this...did you use both of the anti-foulers? or just one? did you drill out both (if you used both)? Or not?
Just for the records, I used both and only drilled out one. |
TooBlue |
Posted: Sep 6 2004, 01:24 PM
Same here, used both, and drilled out only one, like you indicated the photos.
sportyking |
Posted: Sep 6 2004, 03:06 PM
Used both, drilled out both.
| Pages: (14) [1] 2 3 ... Last » |
