S2000 Service Bulletins (TSB) S2000 Technical Service Bulletins issued by Honda to their service network. Covers all model years. Available in HTML and PDF format. (Read only forum)
Water Drips on the Passenger
Old 03-12-2005, 09:41 AM
Administrator
cthree's Avatar
Default Water Drips on the Passenger
Old 10-07-2012, 10:10 PM
XxMerlinxX's Avatar
There seem to be some links missing...
Old 10-10-2012, 05:59 AM
OemEF's Avatar
Same thing happens in mine. I need to replace the weathering around my windows bad.
Old 10-11-2012, 08:52 AM
mazelmazelgoodthings's Avatar
tell your passenger to bring a towel...
Old 10-19-2012, 01:33 PM
SgtDuracell's Avatar
pull the weather stripping a lil bit out to get a better seal.. you're not really being that descriptive as to where its coming from... but if its from the window area.. try that. my drivers side was leaking a bit. i kinda pulled/bent it a bit and it hasn't leaked since.
Old 10-20-2012, 06:23 PM
User 82018's Avatar
If its water dripping directly on the passenger floor(from A/C use), condenser hose may be clogged up. I hope this might help, and please be more descriptive in future posts
Old 10-23-2012, 12:01 PM
kenta's Avatar
If it's getting into the channel at the top of the roof and dripping during acceleration or deceleration all over your left arm or your passenger a liberal application of Shin Estu grease will fix it right up. Happened to me twice since owning the car, after applying the grease to the seals no more leaks!
Old 11-27-2012, 03:53 PM
jbee808's Avatar
I'll definitely try this. The rainy season is coming. Thanks
Old 01-30-2013, 12:22 PM
Hezzbuzter's Avatar
Sounds like that problem I am having. My tops is leaking during acceleration and deceleration from the back and front of the front part of the front seal on the drivers side window (hope that makes sence). When you put your top back it is right where the seals split that is leaking. I was thinking that I needed to get a new seal. You really think this Shin Estu grease will fix my leak?
Old 12-29-2013, 10:38 AM
cheddaboy's Avatar
ttt
Quick Reply: Water Drips on the Passenger
