MY04-05-06 clutch delay slave cylinder removal
Old 04-08-2005, 03:57 PM
SIIK2NR's Avatar
Default MY04-05-06 clutch delay slave cylinder removal
The other day I smoked my clutch bad doing a VTEC entry onto the freeway. The 04 slave cylinder finally me to the point I felt like getting rid of the car.
I finally got around to doing this mod after gathering notes and tools required. Don't be intimidated because the write up is long..... it's easy. I did it for those who might be a little nervous.... you can follow it like a recipe.
TOTAL TIME: 45 Minutes to 1 hour
Tools required:
Honda heavy duty brake fluid DOT 3
Old 04-08-2005, 04:13 PM
03exlcoupe's Avatar
great post! now i just have to find some time to do this mod.
Old 04-08-2005, 05:54 PM
Nate03's Avatar
great post & write up too!
I totally agree this mod is awesome - billman250 helped me by prepping an 04 slave and together at a recent tech day we switched mine for the delayless one...
GREAT MOD!
Old 04-08-2005, 06:47 PM
Member
CrAzYNeSs's Avatar
Great write up
this is just for the 04/05 am i right?
Old 04-08-2005, 06:56 PM
ac09lude's Avatar
i really need to do this - must PM bill
Al
Old 04-08-2005, 07:04 PM
SIIK2NR's Avatar
Originally Posted by CrAzYNeSs,Apr 8 2005, 06:47 PM
Great write up
Yes.....
It's a PITA with the delay intact. I felt like everytime I wanted to go for a spirited drive.
I also lost confidence with any "street encounters" with it in.
With it removed....I've fallen in with my car all over again...
Old 04-08-2005, 07:05 PM
chrisboiii's Avatar
I have no idea what this feels like. Can anyone be more specific as to what the problem is? Does every AP2 have this problem?
Old 04-08-2005, 07:11 PM
SIIK2NR's Avatar
[QUOTE=chrisboiii,Apr 8 2005, 07:05 PM] I have no idea what this feels like.
Old 04-08-2005, 07:18 PM
Nate03's Avatar
clutch slave mod basically eliminates the delay valve in 04/05 slave (cost of labor only) or by using 03 slave (cost of labor plus $60 for slave) -
what you end up with is more responsive clutch feel - no delay on engagement - more aware of greater feel at higher rev shifts...
with OEM 04 slave cyl there is a sense that the clutch is slipping from the delay valve function. with the mod this slipping effect is eliminated.
the hardest part of the mod - if you can call it hard? - is bleeding the clutch. If you want to do this mod to the the 04/05 slave this write up is really good.
all work done is of course at your own risk.
hope this helps.
Old 04-08-2005, 07:49 PM
spapdx's Avatar
subscribing to do this this weekend
Quick Reply: MY04-05-06 clutch delay slave cylinder removal
