Greddy E-Manage Ultimate
I just got back from the nor'easter and had a blast. While I was there I had a e-manage system installed and tuned by Twiztid and gilbertg. All I have to say is wow. My car now has great low/mid range torque.
I will try to scan and post up the sheets some time tomorrow.
OK, I know every one wants to see how much peak power was made. Well I have a stock AP2 and it dynoed at 217hp and 152tq. After E-Manage, Tune and colder plugs i made 232hp and 163tq. That's great that I made 15hp but the big thing is and making 10+ ftlbs of torque before vtec. I picked up 30 ftlb torque at 2200 rpms
. From 2200 to vtec i am making between 136-142 ftlb torque. The torque curve is so flat now. The power increase is very noticeable.
I also autocrossed it today and I never need to down shift. I even let a few NE members take it for a spin around the autocross track and it is very different than stock.
I just want to say thank you to gilbertg and Twiztid for the phenomenal job.
It was soo hot out and you guys worked your asses off in the hot sun.
Update Made more power!
. From 2200 to vtec i am making between 136-142 ftlb torque. The torque curve is so flat now. The power increase is very noticeable. I also autocrossed it today and I never need to down shift. I even let a few NE members take it for a spin around the autocross track and it is very different than stock.
It was soo hot out and you guys worked your asses off in the hot sun. Update Made more power!
Originally Posted by shivers,Aug 13 2006, 10:17 PM
eManage the only thing added to your car or do you have other mods?
We threw in colder plugs ($10). My car was stuttering at 6500rpms on the dyno because the air temp in my air box climbed to 150 degrees
and was causing the ecu to pull timing. We had to walk over to a mini mart and pick up two bags of ice to cool things down. It saved the day (thanks jtpassat). It dropped the temp down to 125 and stoped the stuttering.
might want to post your info either here
https://www.s2ki.com/forums/index.ph...f=142&t=331737
here
https://www.s2ki.com/forums/index.ph...f=148&t=408667
here
