Big-Time Retrofit On My RZ350
Old 12-09-2007, 08:23 AM
Kodokan_4's Avatar
Default Big-Time Retrofit On My RZ350
I thought some of you guys might be interested in my 2-stroke retrofit. This project is to upgrade my RZ350 with modern parts.
I bought (new) 2007 GSXR600 forks, lower fork clamp, steering damper, and front axle from ebay. I'll need to have some spacers made to mount the stem/lower clamp, and weld a bung onto the frame for the steering damper. I'll also need to make new steering stops and get a custom top clamp. I've got an Ohlins shock with remote resevoir and adjuster for the rear.
I looked at using the SUZ RG250 or Aprilia RS250 rear components - but for now, the '00-'01 YAM R1 is my choice because of the underslung rear brake with no torsion arm.
I'm planning on using a CF DUC Monster headlight cover/fairing and a CF headlight bucket, and wrapping the side panels and tail with real CF. I've seen a real CF fuel tank for a Monster, and I'm thinking about wrapping my OEM tank- but I'm not sure yet.
I still have to do more measurements before I can order the BST CF wheels and JMC custom swing arm with eccentric adjusters. Other stuff will include a Vapor electronic dash, Jim Lomas GP pipes with CF mufflers, Brembo brakes/rotors/mc, custom seat, rear sets, signals & mirrors. The frame is going to be stripped, gussetted and powdercoated.
The engine is already built, but I want to get better carbs before it goes back together. I also have new billet side covers and a custom oversize aluminum radiator. I'm excited - it's going to be a whole new 2-stroke bike!
Feel free to comment. I'll post up some pics when I make some progress.
-Pete
Old 12-10-2007, 08:38 AM
DimaK321's Avatar
wow, man
long time, no see
if this will have the quality of your S2000, then OMG!!!
come to bikenight, and we'll chill hollywoodbikenight.com
Old 12-15-2007, 07:11 AM
Kodokan_4's Avatar
The rear end conversion is a nightmare.
Looks like I can't get a carbon fiber wheel for the rear, unless I chop the frame (which I'm trying to avoid). The narrowest CF street wheel is 5.5 inches.
BST told me that they make a 5" rear wheel in CF, but I think that's their Supermotard wheel which looks like crap (IMO).
I'm trying to find out if Dymag can make me a custom rear 3-spoke magnesium wheel:
-Pete
Old 12-18-2007, 04:09 AM
s2kpr01's Avatar
Hey kodokan!
We are going to send you an e-mail today regarding your swingarm
Old 12-18-2007, 07:31 AM
Kodokan_4's Avatar
Originally Posted by s2kpr01,Dec 18 2007, 05:09 AM
Hey kodokan!
Thanks!
I haven't had a chance to reply to your PM, yet.
Your help is appreciated - I sent Maria an update last night.
I got a confirmation email from the Dymag technical department this morning, saying that it looks like they can make the custom magnesium wheels (with a surcharge to adjust the design for the CNC machine).
I'm going to double-check my measurements and place the orders for the swingarm and wheels ASAP.
-Pete
Old 12-19-2007, 07:06 AM
s2kpr01's Avatar
Hey!
Yeah ive been reading the e-mails and that stuff, you are going the super custom way, the bike is going to be badass . Also if you need any aftermarket parts send me any questions, As I can dropship anything to you in the US, also we can send some pics to 2wtmag and you could have an editorial , And as far as I am concerned they are looking for some cool retro bikes .... Let you know!
Old 12-19-2007, 09:14 AM
Kodokan_4's Avatar
Hey kodokan!
Your company is already helping a lot with the project.
I didn't know that the R1 used a 15mm offset swingarm, until you guys let me know.
I think I can remove the offset by asking Dymag to make the wheel hub 15mm narrower on the sprocket side - then if you can make the swingarm 15mm narrower, the wheel should be centered.
If it works, then it's very good for the project. I need the swingarm to be as narrow as posssible to make room for the GP style expansion chambers.
JMC supplies a custom axle with the swingarm, correct?
I also asked Maria if the brake hanger could be made to accept a Brembo Rear Racing Caliper.
I hope I can get the details worked out ASAP - I'd like to get most of the parts ordered before the end of the year.
-Pete
Old 12-19-2007, 02:40 PM
s2kpr01's Avatar
Yeah , Im assuring the best service available , we have to help out fellow s2ki'ers haha , Wheels are sex man , you are going top dollar and JMC is going to be cherry on top, I assure that
Remember post pics!
Anything you need feel free to pm me or e-mail emilio@topfueltech.com or topfuelpr@gmail.com
See ya!
Old 12-22-2007, 01:01 PM
Kodokan_4's Avatar
Front Wheel Info:
Dymag 3-Spoke Cast Magnesium (Gold) 3.5" x 17"
OEM Fitting for 2007 Suzuki GSXR600
Rear Wheel Info:
Modified Fitting for 2001 Yamaha R1
Current Tire/Wheel Center to Frame Distance: 110.5mm
New Rear Wheel: Dymag 3-spoke Cast Magnesium (Gold) 4.50" x 17"
New Rear Sprocket Cush Drive
New Maximum Tire Width: 166mm
New Tire/Wheel Center to Tire Edge: 83mm
New Tire to Chain Clearance: 5mm
New 520 Non-O-Ring Chain Width: 17.5mm
New Chain to Frame Clearance: 5mm
New Sprocket Side Wheel Hub/Spacer: 22mm Narrower than OEM R1
New Dymag Brake Side Wheel Hub/Spacer 8mm Wider than OEM R1
New Dymag Wheel Center to (6mm) Sprocket Center: 96.75mm
New Dymag Wheel Center to Sprocket Mount: 93.75mm
New Dymag Sprocket: 520 x 40 tooth (Gold)
New Dymag Wheel with 2001Yamaha R1 OEM Rotor Fitting
[New JMC Swingarm 14mm Narrower (New I.D.=228mm)]
[New JMC Axle]
[New JMC Brake Mount]
Swingarm Info:
JMC Custom Swingarm with Mega Top Brace
OEM Fitting for 1985 RZ350N Pivot, Linkage and Shock Mounts
Rear Shock: Ohlins with OEM RZ350 Fitting
New Maximum Tire Width: 166mm (160/60-17)
Eccentric Adjusters
Mirror Polishing
Over Length 1"
Donor Wheel: Dymag Modified Fitting for 2001 Yamaha R1
Donor Wheel Sprocket Side Wheel Hub/Spacer: 22mm Narrower
Donor Wheel Brake Side Wheel Hub/Spacer: 8mm Wider
New Swingarm Width: 14mm Narrower (242-14=228mm I.D.)
New JMC Axle
Brake Mount: Bottom Right Side (Under Axle - Brembo Racing Caliper)
Caliper: Brembo Racing Rear P2.24 (64mm Mounting Centers)
No Chain Guard
No Air Tank Fittings
No Engraving
Updated 12/28/07
Old 12-28-2007, 12:55 PM
Kodokan_4's Avatar
Well, I checked my calculations, and I messed up the offset correction.
I think I need to use the following figures:
OEM R1 Swingarm I.D. = 242mm SwingarmCenter = 121mm
Wheel Center (with 15mm offset Arm) = 136mm / 106mm to Swingarm
Reduce Wheel Hub/Spacer Width 22mm Sprocket Side (136-22=114mm)
Increase Wheel Hub / Spacer Width 8mm - Brake Side (106+8=114mm)
Decrease Swingarm I.D. 14mm from 242mm to 228mm
I hope this will center the wheel!
-Pete
Quick Reply: Big-Time Retrofit On My RZ350
