The quest for "Flushness" using AP2 OEM Wheels!
Old 06-17-2016, 08:21 AM
  #1301
Danny_Flash12's Avatar
Can finally join the club! Have 20mm spacers all around.
s2000 by daniel contreras, on Flickr
Old 06-19-2016, 07:00 PM
  #1302
PenguinS2000's Avatar
Droooooool. That looks fantastic!
Old 11-11-2016, 09:33 AM
  #1303
Hondissimo's Avatar
My Setup (later with better pictures)
20mm rear - Tap removed, Fender rolled.
I´m not sure what i do with the front. 15mm or 20mm.
Attached Thumbnails The quest for "Flushness" using AP2 OEM Wheels!-space1.jpg   The quest for "Flushness" using AP2 OEM Wheels!-space2.jpg
Old 11-11-2016, 09:47 AM
  #1304
Hondissimo's Avatar
20mm in the front.
Old 02-06-2017, 12:33 AM
  #1305
Mike RT4's Avatar
15mm spacers and 8½" rears on front with 245/40x17 AD08Rs all round:
The following 2 users liked this post by Mike RT4:
Kobruh18 (11-13-2023), Spoon Fed (01-06-2020)
Old 02-07-2017, 09:25 AM
  #1306
^looks great!
here are some different angles of my set up with a 225 in the front and 255 in the rear with 20MM spacers all around
by https://www.flickr.com/photos/113002456@N08/, on Flickr
Old 02-23-2017, 11:42 AM
  #1307
ITR1649's Avatar
I want to use spacers on my 2005 AP1 but I do not want adjust the fenders etc. I have stock 17" wheels with 215 tires in the front and 245 in the back, KW v2 coilovers.
Will 10 mm spacers all around work? For example the H&R Trak 10mm in the front and the Project Kics in the back?
https://www.all4honda.com/en/webshop...9-details.html
Evasive Motorsports PH: 626.336.3400 Mon-Fri, 9am-6pm PST: Project Kics Wide Tread Spacers - 11mm / 12x1.50 / 5x114.3
Old 02-23-2017, 11:16 PM
  #1308
Mike RT4's Avatar
If I can get away with 15mm, then you will have no problems with 10mm what-so-ever (especially staying with the standard width front wheel), providing you don't go silly with the ride height .
Old 03-10-2017, 09:42 AM
  #1309
Yves_Rogiers's Avatar
My wheels do not have any recessed cutouts.
Can anyone confirm if I will be able to use 20mm spacers with built in studs or will the stock studs still hit the wheel?
Is 25mm the minimum for wheels without cutouts or will 20mm be ok too?
Old 05-11-2017, 03:33 PM
  #1310
Hondissimo's Avatar
20mm all around
Quick Reply: The quest for "Flushness" using AP2 OEM Wheels!
