Sponsored by: Sake Bomb
DIY: Clutch Bleed (Gravity Method)
Old 01-05-2013, 01:02 PM
HvRRZ's Avatar
thank you... that's for the caliper though. Remember the hose needed for the clutch bleed needs to be a little smaller. I'll include those numbers in the brake diy.
Old 02-21-2013, 09:17 PM
BlakeNFR's Avatar
Works great. Even though it's a pain in the ass to get under the car and find this bleeder. I was worried I wasn't going to catch it quick enough and drain my entire CMC. Best with two people. And since there's not much room for a hose to fit down there right, I got the amazing opportunity to try some ATE superblue in my mouth.
Old 02-22-2013, 07:19 AM
HvRRZ's Avatar
Lmaooo! How did the super blue taste?
Old 02-22-2013, 02:50 PM
BlakeNFR's Avatar
I had to chase it out with water, but it was a little numb after.
Old 03-05-2013, 11:13 AM
gptoyz's Avatar
just curious, but you list an SAE wrench, the car is japanese, doesn't it use a metric size?
Old 04-20-2013, 07:16 PM
sillyboybmxer's Avatar
is there any benefit from doing it this way versus sucking the fluid out, topping off with new, pumping clutch, and repeating till all new fluid is in there??
Old 04-23-2013, 11:11 PM
BlakeNFR's Avatar
Yes, actually. You wouldn't do the same with the brakes would you? This allows the brake fluid to be completely flushed out, apposed to being mixed in.
Old 04-24-2013, 06:42 AM
The method I described is a very popular way to change the clutch fluid.......
Old 04-28-2013, 07:56 AM
speakeasy2009's Avatar
Just did this... awesome DIY. Mine was dripping blue within 60 seconds..that stuff flies out so have a bottle ready to catch the crap fluid..
Old 07-18-2013, 06:07 PM
sam i am's Avatar
Why are you using brake fluid to drain your clutch reservoir? I know they are basically the same thing, but wouldn't it be more efficient to use a special clutch fluid?
Quick Reply: DIY: Clutch Bleed (Gravity Method)
