Sponsored by: Sake Bomb
Introducing the FPSpëc Long-Stroke Öhlins DFV
Old 01-17-2017, 10:46 PM
Sponsor
SakeBomb Garage's Avatar
Exclamation Introducing the FPSpëc Long-Stroke Öhlins DFV
Since its introduction, the Öhlins DFV has destroyed the former meaning of “dual duty” suspension. The Öhlins DFV valving design made it possible to have a truly track worthy damper that was also not only livable, but comfortable on the street. As suspension engineers, the one thing that always frustrated us was being forced into the mold of a standard off the shelf suspension settings.
We are proud to introduce our SakeBomb Garage FPSpëc Long-Stroke Öhlins DFV.
Custom Made...For You
We don’t believe in having you dig through forums to try to figure out what spring rates, ride heights and settings other people think are comfortable or easy to drive. Every set of FPSpëc Suspension comes with custom consulting for your chassis and driving style. Spring rates are selected along with matching helpers if needed. Then the dampers are custom valved by Öhlins and filled with upgraded 1304 race oil. Preload, coilover lengths, and height parameters are calculated and set to your specifications, taking the guesswork out of your installation.
30% More Rear Stroke
Longer stroke means more total travel, and completely eliminates the need for pre-load all the way down to 8K spring rates. These custom length damper bodies increase rebound and compression travel to provide maximum performance and drivability regardless of spring rate. Longer stroke also allows the use of helper or assist springs for maximum suspension performance.
Billet Aluminum Lower Mounting Forks
Critical to the FPSpëc design is a single piece billet aluminum rear lower mounting fork. The single piece design increases strength and eliminates wasted length. This allows the exclusive long stroke damper to be installed while still reducing the assembly’s total length. The end result is a lower ride height than the standard Öhlins DFV kit for optimal track performance and appearance, while maximizing travel. On the front damper, a billet fork has been designed to further improve strength.
Custom Rate Swift Springs and Valving
Traditional suspension manufactures are force by accountants to lump all their customers into a single setup to reduce cost. We feel that every customer is different, and we work with you to select the optimal spring rates for your particular chassis and driving scenario. When we say these are the perfect coilover for any application, its because you can customize them to YOUR specific application. These are not just a re-valved standard s2000 coilover, these are a completely bespoke suspension system, specifically designed to meet your needs.
Because every kit is custom designed for your car, you can choose any Swift® spring rates you would like and we will provide bespoke valving for your individual application. From the track to mountain roads to a daily driven workhorse, your requirements are unique so why would you want a one size fits all suspension package.
Along with the higher spring rates required for best track performance, we offer optional Swift® assist-springs to ensure plenty of rebound travel remains to improve corner exit power delivery. Assist springs create a dual rate system that remains supportive on the highly loaded outside wheel but remains supple for the lightly loaded inside wheel providing superb traction. Just like the standard kit, separate spring preload and ride height adjustment ensures a no-compromise suspension setup.
Floating Aluminum Tophat with Aurora Motorsports Bearings and Bullet Nose Studs
Floating aluminum top hat helps to eliminate bending loads on the damper’s shaft reducing friction on the damper and extending the life of your investment. This reduces hysteresis to ensure consistent, predictable suspension performance in all conditions and extends the time between rebuilds. The only choice of top race teams, Aurora’s motorsport series stainless steel, teflon lined spherical bearings provide high strength, silent articulation and will never rust.
Anyone who has installed a damper on the rear of the s2000 has experienced the nightmare that is the fuel filler neck. The 10.9 grade bullet nose studs allow you to simply drop the nut on and tighten without the fear of cross threading.
Same Dual Flow Valve Technology That You Have Came to Love
Derived from Öhlins motorsports heritage, the DFV is uniquely able to provide the damping support needed to snake through a slalom at an autocross yet being silky smooth while attacking the apex curbs at the track. The standard Öhlins DFV kit has become the defacto road & track damper choice for the s2000 and many other platforms due to its impressive combination of body control during aggressive driving while maintaining ride comfort on rough roads. The simple fact is: no other damper near this price point has the ability to keep up.
Custom Setup Advice from the s2000 Suspension Experts
Regardless of if you are looking for the tried and true standard Öhlins DFVs or our exclusive FPSpëc long stroke Öhlins DFV system, we provide individual suspension consultation to help you get the most out of your investment. When your Öhlins box arrives the last thing you want to do is spend hours doing algebra trying to guess as to the best setup for your individual needs. We’ve spent years developing the s2000 chassis and are uniquely qualified to provide expert setup advice to ensure your first drive is fantastic.
High Torque, Non-Marring Adjustment Spanners
When it comes time to make adjustments, we’ve designed an exclusive non-marring high-torque adjustment spanner to avoid damaging the spring perches. With multiple engagement teeth, it provides positive engagement to avoid slippage and protect your knuckles from the wrath of punching a control arm. A 14mm open end wrench is provided for quick removal of the damper force adjustment knob. Also includes a 3/8” breaker-bar attachment for pesky long stuck jam nuts and finally a bottle opener for those long nights in a cold garage.
***SakeBomb Garage does not recommend drinking and driving, only drinking and wrenching****
Already Have the Standard Öhlins DFV Kit?
Although we don’t have a way to increase the stroke of your existing damper, we do offer our same floating top hats and low profile billet mounting forks to improve the performance of your existing system. One of the limitations of the standard system is the ability to lower the car to show or track-ready heights while maintaining sufficient compression travel to ensure a comfortable ride. The billet lower mounts pair nicely with the standard kit to allow optimal performance with the ride height of your choice. The floating top hats improve the performance and reliability of your spring and damper by eliminating misalignment throughout the suspension’s travel.
Even if you decided to purchase your kit elsewhere, we urge you to consider our suspension consultation service. Its included if you buy a kit from us but if you bought your’s elsewhere you can pay a small fee that will be credited towards the purchase of any products SakeBomb Garage carries, most people choose to put the credit towards swift springs for their new dampers.
HIGHLIGHTS:
  • Exclusive Long-Stroke Öhlins DFV Damper Bodies
  • Included Custom Spring Rates and Valving
  • Exclusive Gold Swift Main Springs
  • Exclusive Gold Swift Helper/Assist Springs
  • Billet Aluminum Lower Mounting Forks
  • Billet Aluminum Top Hats with Aurora Motorsports Series Spherical Bearings
  • Billet Aluminum Floating Upper Spring Perch
  • Bullet Nose Studs For Easy Installation
  • High-Torque Non-Marring Aluminum Adjustment Spanners
  • SakeBomb Garage Chassis Consultation and Setup Service
Pre-order pricing is $2795, kits are in the final stages of production and reservations can be made now. Simply shoot us a PM!
Old 01-18-2017, 12:04 AM
Mike RT4's Avatar
Superb - but I hate you for not being in the UK .
Old 01-18-2017, 03:55 AM
mojo_jojo77777's Avatar
This has to be best possible coilover setup under $3k. I really want to switch suspension setup now
Old 01-18-2017, 04:20 AM
B serious's Avatar
Received 1,254 Likes on 948 Posts
Design seems excellent and price point is fantastic. Should be a seller for a lot of people.
SakeBomb Garage (01-18-2017)
Old 01-18-2017, 06:52 AM
flanders's Avatar
Looks great, only thing I can think of that's missing is some "remote" adjustment knobs for the rear dampers
Old 01-18-2017, 12:12 PM
Sponsor
Shoot us a PM, we ship international all the time!
Old 01-18-2017, 06:02 PM
insomnolence's Avatar
Just what I have been waiting for - Ohlins DFV "v.2". I will take a set.
Old 01-18-2017, 11:41 PM
Sponsor
You wont have to wait long...
Old 01-19-2017, 12:18 AM
Mike RT4's Avatar
I would, but Santa has already been .
However, at least he was good enough to provide the SBG recommended rear 10k springs, pre-set them to the correct 10mm of preload AND include the adjustment extenders .
I'm just gutted he didn't know about the floating top mounts or 30% longer rear stroke .
Old 01-19-2017, 12:25 AM
Sponsor
Unhappy
Sorry to hear that but I'm sure you will love the standard DFVs too! If you are ever in the market for low profile rear forks or some high torque non-marring adjustment spanners let us know!
Quick Reply: Introducing the FPSpëc Long-Stroke Öhlins DFV
