Need help adjusting Ohlins
#31
-Greg @ SBG
__________________
SAKEBOMB GARAGE > Click here to contact Us
Check some of our most popular products for the S2000:
- Ohlins DFV Billet Lower Mount
- Rear BBK RX-8 Caliper Conversion
- Front BBK AP Competition
- Setrab Oil Cooler Kit
#32
Was referring wheel movement before arch contact
Available damper rod stroke would be changed with preload,and keeping within compression range of spring,
droop is of concern with too much preload or lack of droop,and wheel lifting on cornering ,have 13-14mm preload with an 8Kg and 4.5mm remaining bottom bracket adjustability remaining, have 33.5cm wheel center to arch on all for corners.
#33
Just announced the solution to your DFV rear ride height vs preload trade off! Check out the link below for details.
https://www.s2ki.com/forums/sponsor-...ssues-1166726/
__________________
decepticondc5
12-25-2016 01:49 AM
boiii4
07-04-2011 06:19 AM
