View Poll Results: What tuning system do you run and prefer?
AEM EMS
49.16%
Hondata
45.25%
Other
5.59%
Voters: 537. You may not vote on this poll
AEM ems vs Hondata
Old 01-10-2015, 08:22 AM
  #101
turbodreamz22's Avatar
What if you plan on turboing an 07 S2000 and you want to run Hondata to be able to pass emissions and all That. Hondata doesn't work for 06+. So what do you do in that scenario where you don't want to run aem.
Old 01-10-2015, 01:59 PM
  #102
JUSTINTHECOASTIE's Avatar
Hondata Flashpro does work for 06+
Old 01-30-2015, 07:11 PM
  #103
K20iVTEC's Avatar
Originally Posted by riceball777
The main reason I like aem is for the flex flex compatibility. It's really is like a dream come true to be able to run 91 octane and switch to e85 and run any amount of ethonal mix with out change tuning maps and without emptying the fuel tank of pump gas or e85. The aem ems will adjust boost pressure timing all automatically by how much ethonal you have in your tank.
k-pro 4 has flex fuel compatibility....
Old 01-30-2015, 08:34 PM
  #104
VitViper's Avatar
Let me list the things AEM Infinity can do for you...
Old 01-30-2015, 10:24 PM
  #105
Chitoki's Avatar
^ Agreed! I have both Kpro4 and Infinity. Any reason why the car feels stronger with Infinity vs KPro, both 91 and both same timing settings. I have one advisor suggesting I pull the infinity and one suggesting I leave it in there. I am in an emission compliant state, with my setup I can easily swap out either ECU in a matter of seconds. Im supercharged with flex fuel... is infinity overkill for me or still above kpro4 in your opinion Vit?
Old 02-02-2015, 06:24 PM
  #106
VitViper's Avatar
AEM Infinity > * on this platform as far as I'm concerned. Having a super fast ECU allows the tuning to be that much more accurate, which can indeed make the car "feel faster". The Infinity also has TRUE VE fueling based on the ideal gas law, not a time based system anymore, which also lets it be a true and proper flex fuel ECU. I love what Hondata has done with the KPro4, and I used a ton of their products on my own cars (FlashPro, S300, TC, CPR), but as far as it came to the S2K, Infinity hands down.
Old 02-03-2015, 08:41 PM
  #107
06Estukay's Avatar
+1
I've tuned on both. For me, the Infinity is the hands down winner in every which way (except for the obd2 emissions stuff obviously.)
You can't surmise that the Kpro compares favorably to the Infinity just by comparing the feature sets on paper. The way in which the feature (i.e. Flex fuel) is handled by the ECU makes a huge difference...
Also, don't get me started on tuning the Kpro. It's slow and laborious.
Old 02-04-2015, 08:46 PM
  #108
VitViper's Avatar
The graph UI needs an overhaul, anything more than a couple minutes of data and it craaawwllls. Not a problem in the new FlashPro Manager software. The FPM software is by far the slickest OEM based ECU software I've used to date, Hondata hit it out of the ball park on that one.
Old 02-05-2015, 06:43 AM
  #109
06Estukay's Avatar
Totally. I learned to tune on Flashpro. Great for an oem ecu indeed.
I found the Kpro a bit buggy. Live tuning was hit or miss, which made tuning on the dyno slow. More time on dyno = more $$$.
Old 02-05-2015, 01:47 PM
  #110
VitViper's Avatar
That's cause until like a month ago KPro has never had live tuning. Very fast updates after the first flash, but their recommendation is to key off the car between updates.
Quick Reply: AEM ems vs Hondata
