Evans Tuning e-tune review
Old 10-11-2011, 04:06 AM
//steve\\'s Avatar
A testpipe is definitely a must in my opinion but I'm not 100% sure on the exhaust yet. And if I'm paying for it I want him tuning the setup that will actually be on the car.
Old 10-11-2011, 04:21 AM
Biohazard's Avatar
Originally Posted by Syn
Mine is 4200. You can get down this low with just a testpipe--it is the piece that allows you to drop the engagement point, not a header or catback. The other two pieces in addition may allow you to go lower yet, though.
He sends you a base tune based on your mod list and you go from there.
I am set at 3600 with intake, testpipe, and exhaust for those asking for a lower vtec. Seamless!
Old 10-11-2011, 10:19 AM
MegaTRon's Avatar
did you run the Toda callibration before getting tune by Evan? Can you compare the Toda callibration vs Evan's?
Old 10-11-2011, 10:26 AM
Biohazard's Avatar
yes, we did an overlay on the two different tunes (toda tune and custom). Jeff got me a bit more mid range and top end power and more importantly the afr were consistent at 12.9 at open throttle on 3rd gear pull, power was more linear, fuel milage better on highway, and 0 knocks.
Hope this helps
Old 10-11-2011, 10:44 AM
MegaTRon's Avatar
thanks. i guess its time to get e-tune! lol
Old 10-12-2011, 05:53 AM
Syn
Syn's Avatar
Yeah, I ran the Toda flash for half a day after swapping in the testpipe and before submitting the etune payment. There was knock in my datalogs (not a whole lot but it was there) and more importantly the car simply did not run smoothly. A/F ratios were all over the place.
If you eliminate your cat I would suggest running on a preloaded tune only as a very temporary fix until you can start on a custom tune--and I would definitely not push the car on a preloaded tune. It's not worth it to risk the engine not to mention all the power and MPG left on the table by using a canned tune.
Old 10-12-2011, 06:36 AM
ryanvo's Avatar
i had etune by Jeff Evans too. car runs better than stock, makes more power than local tuner. we did about six logs. just dyno 376whp, 235 tq compare to 373whp, 230 tg from local tuner. i think Jeff is excellent tuner, highly recomended.
Old 10-12-2011, 07:15 AM
mrscbw's Avatar
What are your idle and part throttle afr's at? Also, did you notice any significant changes on the ignition map?
Old 10-12-2011, 07:27 AM
//steve\\'s Avatar
I'm really tempted to look into this. I'm most impressed that you boosted guys are able to get good tunes without being in front of a tuner on a dyno.
Old 10-12-2011, 07:28 AM
mrscbw's Avatar
I am curious on how they would work the ignition map..
Quick Reply: Evans Tuning e-tune review
