AEM Infinity
Old 01-16-2017, 12:40 PM
  #41
E4RTH WORM JIM's Avatar
Originally Posted by neeman77
Car just would not run, so frustrating. Ended up being that the plug to the map sensor didn't have 5v source going to it. I had to bridge from the TPS to the map for 5v signal. After dealing with AEM tech it seems like they knew it was an issue and didn't do anything to make the situation better after hours of diagnostics at my expense of time and money.
Good old AEM!
Old 01-16-2017, 12:50 PM
  #42
Spoolin's Avatar
Would I likely have to bridge mine also then?
Old 01-16-2017, 03:36 PM
  #43
snitm's Avatar
Originally Posted by Spoolin
Sure hope I don't have that issue with my AEM harness when I go hooking things up this spring. What ended up being the issue and has AEM resolved it? Was it possible it was just this one harness or could others be effected?
Very likely a one-off. neeman77 is doing some quality hand-waving while attempting to explain AEM knew it was a problem and didn't do anything about it. Not doubting he had a bad harness, just doubt it is a general problem with the AEM pnp harness. My AEM pnp harness works fine with my Infinity.
Old 01-16-2017, 05:16 PM
  #44
Spoolin's Avatar
Good to know, thanks.
Old 01-16-2017, 05:32 PM
  #45
tunermt's Avatar
Of all the plug and play Aem harnesses with infinity I've installed/tuned there haven't been any major problems all easy install and tuning including the s2000, I'm sure you'll be ok.
haha the s2000 app does have a lot of ecu/wiring to mount but you can get it all to fit behind the plastic kick panel without to much fuss.
Old 01-17-2017, 05:03 AM
  #46
neeman77's Avatar
Just explaining my experiences and the impression I got from AEM tech that this was not a one off issue. I have nothing to gain or lose providing this info. I am sure the few that had issues were early harnesses as I had one of the first available, I actually intended to give SOS my support rather than bring down AEM with my initial post.
Old 01-17-2017, 05:51 AM
  #47
V6 Donut's Avatar
I have a few friends and myself on aem infinity with their PNP harness. None of us had any issues.
Old 01-17-2017, 07:32 AM
  #48
neeman77's Avatar
Maybe just a one off then, bad luck!
THMotorsports
12-12-2015 02:45 PM
rtboy10
Member S2000 Classifieds and For Sale
11-03-2011 12:52 PM
ekoms31
05-23-2010 07:00 PM
ShMooveS2k
07-08-2007 08:29 AM
APLUS2K
03-18-2005 10:19 AM
Quick Reply: AEM Infinity
