EFR 7064 Twin Scroll / IWG / Pfab Top Mount / V-Mount build
#41
The EFR turbos have an excellent IWG. The vented exhaust never really makes it into the turbine housing, which is another reason why I chose this turbo to run IWG with. I don't suspect the boost threshold to be so high that spooling this turbo will be an issue. When I sized the EFR for my STi, I went with a larger hot side than most at .85, but it has reasonable spool and doesn't choke up top. It is also a T25 flange. Many of what you've stated is why I elected to build my own setup. There wasn't a single kit out there that met all the requirements I had.
The battery will probably have to be relocated. I used a 4ish lbs battery, so it should be pretty easy to fit anywhere.
#42
I've fancied the idea of hodge podging together my own turbo kit with a greddy style log manifold, upgraded gt30 turbo, and an SOS V-mount setup. In theory I think it would be ok, but my biggest concern would be the manifold being a restriction. My free time has been bogged down with kids lately and I don't even get enough track time.. Me personally, 320-350whp would be plenty. My car is still a street car so keeping AC/not relocating the battery/etc is nice. Definitely excited to see how this turns out.
#45
sick build bro, cant wait to see the finished product. (i have been lusting after that v mount setup as well, but im going to experiment with my setup for now before i bite the bullet).
#46
Thanks. I'm pretty excited about it all. I'm trying to do it all right the first time... I've overlooked things in the past which were fine for a street car, but then killed a motor on the road course. That's been over a decade ago, but you never forget.
#47
l am already subscribed to your thread. I'm already following it. It's coming along nicely and when you want to upgrade spring rates, I might have mine for sale to go even stiffer. I should see you out at MAM/RPM this year as I want to do a Fast Friday and a MACE Roll Race event.
#48
I think they open up in May, but there should be a schedule posted on their website. As for alignment, I know a guy at the Honda Dealership that can get you squared away and maybe I can work out the same deal I had with him for alignments.
#49
At which dealership? i usually go to the shop inc in lincoln. may is pretty late, thought the weather would clear up much sooner than that
